308 noise from steering
Auldalliance
- x 9
308, '08, 1.6HDi. Recently brought back to life after starter motor failure.
I've just been using it up and down the driveway to move a trailer with logs, and it's started making a horrible twang/clonk noise from the steering. Not a constant clicking with every revolution of the axle, but a one off as the steering moves through a particular position. Seems to be somewhere in the region of the driver's side.
Any suggestions for what this might be?
Have I buggered something up when I changed the starter?
PaulC5
- x 698
Re: 308 noise from steering
Check the suspension coils in case one has broken. Can be other things but this is easy to do.
- x 1472
Check the springs. Also check or replace the top strut mount bushes, as they are often torn, allowing the strut to move around causing metal to metal contact.
- x 1496
If it's not broken a spring, probably the bearing between the spring and the top mount has disintegrated - if you turn the steering the spring and strut should rotate smoothly, if the top kags behind and winds the spring up before it then jumps round, the bearing is toast - they're cheap and nasty and are always shot when you take the spring out!
Auldalliance
- x 9
OK finally found time to look at this and, yup, the spring has popped partly off. Haven't looked to see if it's actually broken but I don't see/feel anything obvious. So maybe it's that top bearing?
Auldalliance
- x 9
Oh it's definitely broken.
Just had the wheel off and I've fished out two separate pieces of spring. One break looks fairly clean, the other is quite rusty, so the first bit must have broken off a while ago.
Nearest garage is about fifteen miles away... car still seems to be driving ok around my driveway... and if avoid full lock there are no horrible noises... but I'm assuming it would be a pretty big risk to actually take this out on the road like this?
Auldalliance
- x 9
That's quite a lot of spring I think...?
- x 8147
That certainly is a handsome chunk gone missing in two parts!! Personally I would suggest that it is not safe to drive on public roads as a single heavy jarr such as a pothole may dislodge the spring completely causing all sorts of secondary issues. I don't know but it may even be illegal to drive as it would probably be declared at an MOT as dangerous. The safest course of action would be to have it recovered to the garage for spring replacement and I would advise replacing both springs as a pair.
PaulC5
- x 698
Springs can move and cut into tyres when they break so driving is probably not a good idea as it could end up costing a lot more. If you are having to pay for recovery then you might try a mobile mechanic since it is not difficult to replace a spring with a couple of spring compressors and should be around 1 to 2 hours work.
- x 5675
I was driving my daughter's C3 when a spring broke, didn't 'stab' the tyre but deformed enough that the coil rubbed on the tyre and wore through it and it went off with an alarming bang.
Auldalliance
- x 9
Ok car is off the road until this is fixed. Thanks everyone!
Auldalliance
- x 9
I'm baaaaack.
Time to get this car back on the road.
What size spring compressors should I get?
PaulC5
- x 698
Buy the new springs and get compressors that open up enough to fit them. 3 of them can make it easier when you fit the new spring to the strut off the car. If you do not want to buy them, you could take the struts and springs to your nearest garage and ask them to put them together. They might have a hydraulic compressor which makes it very quick and easy.
When you buy springs copy parts might not perform the same as originals which should have coloured bands on them identifying the Peugeot/Citroen part so something to check.
Auldalliance
- x 9
With the help of some heat, managed to undo the two bolts at the bottom of the strut.
And then noticed this small metal band on the ground.
Would it by any chance be the ring for the ABS?? I hope not...
https://ibb.co/nqsQ5Lzp
- x 1496
