- x 5672
The dash is also the same as my dad's 1100, the first in Whitby and one of the first in the country.
302 CVN.
He loved the registration as he worked in the 302 building of the Fylingdales BMEWS.
302 CVN.
- x 8412
Bet he needed a big driver when playing with those big golf ballsmyglaren wrote: 10 Oct 2026, 09:40 He loved the registration as he worked in the 302 building of the Fylingdales BMEWS.
- x 5672
- x 8412
Buried under houses?
That seems to be about par for the course these days
- x 5672
Replaced with a phased array radar.
Haven't been to this one but did work at the former one for a bit. Had a tour of it too. The antennas were huge, the size of a football field, and would 'swish' back and forth very quickly and silently, very impressive. As was the blue 'flame' that could be seen through the observation ports in the waveguides.
Less impressive was almost getting taken out by a golf ball -a real one - when entering one of the support buildings, the communications centre with America. Yanks playing indoor golf there, lethal.
This one was notable for its effect on a Subaru that was owned by a Whitby shop owner who lived in Malton. As she passed it, the car would die and she would call the AA to rescue her.
They couldn't find a fault and having removed it from the vicinity of the radar, it would be perfectly OK. She had to use an alternative route until she changed cars.
I imagine it is redundant now, superseded by satellite technology.
- x 8130
Next time I come up there Steve I must do a drive by and see if all is well!!myglaren wrote: 12 Oct 2026, 09:42 This one was notable for its effect on a Subaru that was owned by a Whitby shop owner who lived in Malton. As she passed it, the car would die and she would call the AA to rescue her.
- x 5672
Haven't heard of anything similar recently.
Zelandeth
- x 1607
The Morris had a pretty horrible miss when it arrived here. It felt to me like fuelling so I did the right thing and immediately looked at the ignition system.
Mmm...crusty.
This much oxide gunk was removed just by hand.
That definitely won't have been helping anything.
Took it inside and gave the terminals a going over with the little brass brush attachment on the Dremel. Nae perfect, but a million times better than they were.
Not having about 1/16" of solid crust on should help. Pretty standard stuff for a car that's not in daily use and sits around for long periods.
The points were similarly crusty so got cleaned as well. Didn't mess with the gap as it looks reasonable and getting to the feeler gauges would involve moving three cars and I just didn't have time.
Only had a brief run round the block, but definitely feels like it's running smoother and is just more willing.
Hoping to use the car for tomorrow's local errands so will get a better idea of if it's now running as it should be again then.
Really does feel like with the state of the roads these days that a Hydrolastic sprung car (or oleopneumatic Citroen) really is the answer to comfort. Yes the body control is sometimes a little... interesting, and it can be bouncy on the wrong surface - but I'll take that occasional lack of composure over smashing the fillings out of my teeth any day of the week.
Mmm...crusty.
Current fleet:
- x 8412
Good work Zel
I must say that new phased radar array is nowhere near as easy on the eye as the radomes were...
Zelandeth
- x 1607
Oh joy. Apparently I'm going to need to go find some black market solder now.
Have lead free stuff in stock already and it's generally used for new applications - but it and leaded solder really don't mix well and about 90% of the kit I work on already has leaded stuff in it. So for repair work I'm not interested in having to totally desolder and redo every joint I touch.
Current fleet:
- x 8412
Oh gosh Zel
That is just so OTT...
I bet EvilBay will happily provide
- x 3296
https://www.ebay.co.uk/itm/317855061023 ... R_iZnb6naA
https://www.ebay.co.uk/itm/136999352065 ... R_iZnb6naA
https://www.ebay.co.uk/itm/357800333648 ... R_qZnb6naA
Zelandeth
- x 1607
Further to the putting together the PDP-11, I needed something appropriate to actually interface with it. Terminal emulator on a modern PC is entirely too boring, though thankfully something suitable was sourced from the same place as several of the cards.
Step forward, one slightly sorry for itself looking DEC VT 100.
It's a "bit yellowed."
Not to mention filthy.
Though there's zero screen burn, and a quick look inside suggests that this one doesn't have mega numbers of hours on it.
Also has an expansion card of some description.
Be interesting to see if that adds any useful capabilities.
Job for another day though, I literally just had time for a really quick visual inspection.
Another piece of the puzzle arrived today (after some delays thanks to fun with Royal Mail) in the form of an appropriate keyboard for it.
You *can* use a modern PC one, but it involves having to build an Arduino based converter as they communicate in totally different ways...
...And I really don't have the patience for messing about like that. Plus using a modern keyboard would defeat half the point of having sought out an era appropriate terminal in the first place!
Need to do some basic electrical checks and dig out a cable for it, but I'd not honestly be surprised if this just works as they're built like tanks and tended to be stupidly dependable - and usually still are, physical or water damage non withstanding, and I seem to have escaped that from what I can see.
Will I also feel the need to use this to log in to my main workstation PC once it's up and running just because I can? Or course!
Current fleet:
- x 8412
Excellent Zel
I'm following this PDP-11 adventure with great interest!
Zelandeth
- x 1607
Well I don't see any immediate red flags. I don't know where my proper capacitor reformer box is (a sign of how long it is since I've played with any valve gear), but the big high voltage DC reservoir caps reformed fine with zero leakage up to the ~40V I can coax out of my bench top supply. Generally I've found if they're going to be leaky they'll do it as soon as there's any appreciable voltage there. So they're probably fine.CitroJim wrote: 17 Oct 2026, 05:36 Excellent ZelI'm following this PDP-11 adventure with great interest!
Think to be honest given the reputation these have I'm going to pull the cards, clean the edge connectors and then just plug it in and see what happens.
Of course can I find any of my 25-pin serial cables? Or null modem adapters (which I can't remember if I need or not)? Probably deeply buried in a box that's even more deeply buried in the loft given I don't think I've used them this century... buying another one feels like giving in, but is probably by far the lesser of two evils here! Especially given I'm very much short on time and that's only going to get infinitely worse in a couple of weeks. So going spelunking in the loft probably isn't going to happen.
Current fleet:
