My normally reliable Nemo, let me down today. Went out for 2hrs as normal perfect and then had to go out again. 400yards from the house the engine made a sound like gravel on the wheel arch and died instantly. I have removed the top cam belt cover and checked the cam belt is ok and the engine turns over normally, speed and effort but is completly dead, like a switch was turned off
Any experts out there who can offer advice ? Thanks
Nemo 1.4HDI 2010
- x 1489
Re: Nemo 1.4HDI 2010
Welcome along
Is this a 16 valve engine? Did you crank it with the belt cover off - DV engines like to strip teeth off the belt, so can look OK at the top, and be under tension, but not go round when cranked.
Nemo6
think it is just a basic 8v and I had someone crank it over whist i watched the crank turned and the camshaft so I would suppose it was ok, thanks for taking the time to reply
- x 1489
Need a diagnostic session - usually these only stop suddenly if the cam belt breaks, but there are always exceptions. Want to look at live data to see that you have engine speed signal, crank / cam synch, and fuel pressure when cranking. This will give you a pointer as to where to look.
Nemo6
found the problem, one little cord had come out from the fan belt and pulled the crank sensor plug off. All good now thanks
