marelli radio RT6 2.8 firmware
x 1953
Re: marelli radio RT6 2.8 firmware
Check your PM in 5 minutes. It's 2.86 but I can't guarantee what sub version it is.
Slavic
Unread post by Slavic »
Hi, I have the same Problem in my Peugeot 308cc with the RT6 unit. Would it be possible to get 2.80 version ?. Thanks and Kind Regards:)
x 1953
Check your PM.
vargapeter68
Unread post by vargapeter68 »
Hi, can anyone help me with the RT6 2.80 firmware?
I need RNEG2.80.E.2 / 9691737180 for my Peugeot 5008 RT6.
I would really appreciate a download link. Thank you!
x 1953
Answered in your other post.
Please don't double post, it doesn't speed things up and only causes confusion amongst the easily befuddled people like me.
Jan Gla
Unread post by Jan Gla »
Hello,
I still haven't resolved the issue with the RT6 2.8 radio in my 2014 Citroën C5. The problem was that the radio kept shutting down and restarting every minute, though occasionally it would run for longer periods. Paul helped me with software version 2.86; I installed it onto a new 32 GB SanDisk SD card. I performed the installation using a CD, as I couldn't get it to work with a USB drive. After the installation finished, the Peugeot logo appeared, but the steering wheel controls didn't work, and the radio kept restarting every minute. I removed the SD card and copied the settings from the old card—specifically the files in `user_data` – `user_profile` – `user.config.dat` (and others)—over to the new one. I put it back in the radio, and now everything works except the Bluetooth connection; however, the connection likely can't be established anyway because the radio shuts down and restarts every 30 seconds. I suspect the fault might actually be with the hardware rather than the SD card. I’ve attached a screenshot of the `user.config.dat` settings. I read that Bluetooth could be the issue, so I used the DATEXPLORER program to change the BT setting in the config file from 1 to 0, but that didn't help. I don't have the navigation maps yet. Perhaps someone has experience with this kind of problem?
Gonpdr
Unread post by Gonpdr »
Hi there i need the firmware 2.80 for my radio, the screen is black and the cd drive don't stop making noise, I have a Peugeot 3008 4hybrid
x 1953
Check your PM. Usual conditions, use at own risk, etc.
mensur
Unread post by mensur »
hi Paul-R could you please send me the link to download firmware for RT6 2.8
x 1953
It's actually 2.80, not 2.8.
Check your PM. Usual rules. Use at own risk, etc.
vitinha_gomes
Unread post by vitinha_gomes »
Hello Paul-R can you send me the link firmware 2.80 please. Thanks
x 1953
I can but first tell us why you're asking for it please?
vitinha_gomes
I bought an RT6 to replace my RNEG and installed firmware 2.86, but I can't configure it via Mirascript.
When i read the usercom I request that the files be saved, none are saved when I try to verify them on my PC.
I already uploaded modified files not from my radio to see if it would also have the option to write, but it doesn't.
I read that version 2.80 allows you to make this change and I wanted to try it.
x 1953
If you've installed 2.86 then there's no way to go back to an earlier version unless you have a well equipped electronic workshop. I'll send you a link for 2.80 shortly, check your PM in five minutes.
pepefer
Unread post by pepefer »
