DS3 1.6 HDI - Maintenance Schedule?
joaocpereira
- x 3
My DS3 1.6 HDI 92HP end 2015 service light came on after the mileage counter finished. That's fine. My question is, according to the seller, the car had its 15,000km service. The internet says the maintenance intervals are 25,000km or 1 year. The seller said the DS3 will always have the light come on after 1 year because the car assumes it's every year. Is this true?
joaocpereira
- x 3
Re: DS3 1.6 HDI - Maintenance Schedule?
Btw, the VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Also, on Citroen putting that VIN shows that is a DV6FD FAP... however, my car is the 92HP... is that correct or the car could have the engine changed to DV6TED ??
- x 1938
The service schedule is based on mileage OR one year, if you don't reach the recommended mileage. This is my service schedule and it clearly says "The service interval depends on time and mileage. The service is due when the first of the two terms is reached".
As regards 25,000km or15,000km my best guess is that these are the normal conditions and arduous conditions mileages. These roughly correspond to 16,000 miles and 10,000 miles on my schedule.
joaocpereira
- x 3
Thank you, so the car just did 10000km so that's why the light is on, cause already did one year since last service.Paul-R wrote: 16 Sep 2026, 20:02 The service schedule is based on mileage OR one year, if you don't reach the recommended mileage. This is my service schedule and it clearly says "The service interval depends on time and mileage. The service is due when the first of the two terms is reached".
About the oil, now im confuse about what engine the car is (DV6FD FAP or DV6TED) but the oil as to be the PSA B71 2312 C2 or C1? Let's belive the car is the DV6FD
joaocpereira
- x 3
It's 99CV, 73KW. So is DV6FD. The difference on C2 and C1 is?
- x 1938
PSA B71 2312 0W/30 will get you the right oil regardless of those other specifications.
joaocpereira
- x 3
Paul-R wrote: 16 Sep 2026, 21:14 PSA B71 2312 0W/30 will get you the right oil regardless of those other specifications.
Thank you. But why are 2, C1 and C2? what is the difference? Depends on the country temperatures for example?
PaulC5
- x 675
Our 1.6 hdi Cactus uses that oil spec so I use Total Ineo First 0w30 which meets it. I change it every 12 months in which time it does about 8k miles.
joaocpereira
- x 3
Thank you. Btw the coolant what is recommended, the car have a green one, generic...PaulC5 wrote: 16 Sep 2026, 23:10 Our 1.6 hdi Cactus uses that oil spec so I use Total Ineo First 0w30 which meets it. I change it every 12 months in which time it does about 8k miles.
- x 1938
It's to do with the viscosity of the oil and the amount of ash produced when it is burnt inside the combustion chamber. This is what the internet thinks-joaocpereira wrote: 16 Sep 2026, 20:58 It's 99CV, 73KW. So is DV6FD. The difference on C2 and C1 is?
C1 and C2 engine oils differ primarily in their SAPS (sulphated ash, phosphorus, and sulphur) content and HTHS (high temperature high shear) viscosity. C1 oils have lower SAPS levels, making them suitable for vehicles with sensitive emission control systems, while C2 oils have mid-SAPS levels and are designed for broader compatibility with modern engines.
Summary of Key Differences
- SAPS Levels: C1 oils have lower levels of sulphated ash, phosphorus, and sulphur, making them ideal for vehicles with advanced emission control systems. C2 oils have mid-SAPS levels, providing a balance of protection and emissions compliance.
- HTHS Viscosity: C1 oils are designed for lower viscosity, focusing on fuel economy, while C2 oils have a higher minimum HTHS viscosity, offering better protection under high-temperature conditions.
PaulC5
- x 675
If you buy the anti freeze from Citroen/Peugeot/DS they will sell you this (part number 1637756080 concentrated) which is a blue colour but the colour means nothing as manufacturers can make it any colour https://www.ebay.co.uk/itm/185261405665 ... adtype=pla
