Airbag, Dashboard, Seat Belt & Airbag ECU Repairs
Handy links to other sites (car related) suggested by members
Danhopper2001
Re: Airbag, Dashboard, Seat Belt & Airbag ECU Repairs
Unread post by Danhopper2001 »
2011 Citroen ds3 1.6thp fault. Please help just passed test
Just bought a citroen ds3 that currently has two faults. The first being a battery drain somewhere causing the battery to die after 4 days of no use. Has a brand new battery fitted to it. As well as a light on the dash and a message to go with it as follows: air bag/seat belt pre tensioner faulty” any help would be greatly appreciated as paid over the top for the car and insurance is a joke. Thank you. I’ve already checked through the forum and either didn’t see current info on the fix or I’m being ignorant.
x 6956
Hi and welcome - we really need the fault codes. The warnings do not provide a definitive reason - only that the Airbag ECU has detected a fault on the self-check. You need to have it read with Lexia / Diagbox and put up the fault codes along with your VIN here for assistance.
Gigilamoroso
Unread post by Gigilamoroso »
Hi I have a Peugeot 307 cc 2007 and the airbag light keeps coming on and off. I checked under the driver seat and found the connector loose. I compared with under the driver seat and found that there’s a piece of plastic that seems to hold the connector to the floor.I used zip ties etc but to no avail. Is this something that can be sourced?
Stonehopper
x 118
Unread post by Stonehopper »
I don't have knowledge of the Peugeot, but the issue of a loose connection is known with several makes of car.
I doubt the piece of plastic holding the cable to the floor will cause an issue with the air bag light, but an intermittent loose connection in the plug and socket almost certainly will. Check for a good electrical connection within. Look for corrosion, dirt, and maybe spray the connection (whilst apart) with a spray cleaner for electrical connections.
Derek
FinnCitro
Unread post by FinnCitro »
Hi
Last summer I had a problem wlth the stearing angle sensor.The remedy, so I was told, buy a used COMM 2002 unit and because my car is a 2005 model the comm unit must be 2005 or older. This is because Citroeng changed their protocol from CAN/VAN to full CAN at the of that year.
So the car was waiting for new unit and stayed outside in the rain for three weeks.During that time water got into the the ECU and the result was one broken pin.I will receive the repaired ecu tomorrow.
The question is, if I buy another ecu as a reserve, must it also be 2005 or older ?
Any other comments ?
Best Regards
C.E..
FinnCitro
I I gorgot
The car is a citroeng C2 1,6L VTS 2005
