Ongoing uneven tire wear — suspect upper control arm bushing
david2010C5
- x 3
Hello everyone, I'm new to the forum and hope I'm posting this correctly.
I have an ongoing issue with uneven wear on one of my front tires, and I believe the cause is the rubber bushing on the upper control arm. I've had trouble identifying the exact part and will try to upload a photo of it if possible.
A bit of background on what I've already done:
I first replaced the control arms,
then replaced the outer CV joints,
...and it was only after all of that that my mechanic pointed out that the rubber bushings on the upper control arm were completely shot. The rubber at the bottom of the bushing appears to be worn out entirely. As a result, the wheel/tire moves in all directions when I drive, except where I'm actually steering — the car feels loose and unpredictable on the road.
My question is: Is the rubber bushing something that can be replaced on its own, rather than needing to replace the whole upper control arm again? If so, I'd really appreciate any help identifying the exact part I need.
Any advice would be greatly appreciated. Thanks in advance!
PaulC5
- x 674
Re: Ongoing uneven tire wear — suspect upper control arm bushing
Any details of the car other than in your My Cars list which suggest a 2010 C5 diesel ? Things such as engine size, estate or saloon, hydractive or standard suspension (a close look at the top photo looks as if coil springs) might be relevant. Have you tried autodoc or other suppliers for bushes ?
david2010C5
- x 3
Thanks for getting back to me, Paul.
I haven't approached any suppliers yet, because I'm still trying to work out exactly which bushes I need to replace. The part I'm unsure about is the larger component the bushes sit in — I'm wondering if that's properly called the upper control arm, or whether it goes by a different name. I've struggled to find a diagram that lets me positively identify the part.
For reference, my car is a 2.0-litre diesel Saloon with the standard suspension.
- x 1998
david2010C5
- x 3
Thanks for the link to the diagram, Alasdair. It's helpful, but there's one part it doesn't address. I'm hoping to replace only the rubber bushing where the lower control arm connects to the upper control arm — the diagram doesn't show it as a separate part. The bushing I'm referring to is at the bottom of the smaller picture I uploaded above. Can anyone confirm whether it's possible to replace just this bushing on its own?
Sloppysod
- x 391
Stu
david2010C5
- x 3
Hello Sloppysod I wish it was That looks like the two that are at the top numbered 13 on the diagram. What I'm looking for is the one at the bottom of the same port numbered B
Sloppysod
- x 391
Well looking at the diagram, Alastair posted, I think you are out of luck, the bush at the bottom of that part (Front Swivel Assembly) is only available with the bush already fitted.
Stu
david2010C5
- x 3
Not what I wanted to hear but thank you. Does this mean that it is going to have to be a genuine Citroen Port. Is there likely to be an aftermarket part available.
Sloppysod
- x 391
You need to do some digging to find out if an aftermarket part is available, but remember, some Peugeot may fit.david2010C5 wrote: 08 Sep 2026, 13:32 Not what I wanted to hear but thank you. Does this mean that it is going to have to be a genuine Citroen Port. Is there likely to be an aftermarket part available.
Or, if you have time, take the bush out, and search for a bush that measures the same, there may be something out there.
Stu
- x 1998
These ?? (Note, 407 is the same suspension basically)...the wording is correct and a split supported bush is technically logical in that application. Zoom it and they look (??) the same.
https://www.ebay.co.uk/itm/164176896633
bigblackfalco
- x 11
I had uneven tyre wear on my steel sprung X7 and it was the Fripp Joints / tracking out of true. The wear was on inside edges of front tyres.
58 plate (2009) C5 Tourer 2.0 HDi VTR+
david2010C5
- x 3
Hello Stickyfinger and Bigblackfalco,
When I look at the bush in the link, it looks identical to the one in my photo in my first post. I'll look into getting that bush.
I've traced the part locally through my South African agents, but it's more than I can afford right now, since I'll also have to buy tires because of the damage. My tire is worn on the inside.
Bigblackfalco, you say this could be the Fripp Joints. Can you please point out what the Fripp Joints are before I chase down and replace the bush?
This whole issue started when the tire shop told me — and demonstrated — that the wear was coming from the control arms, so I got the control arms and had them fitted. It made no difference. They then said it was the CV joints, so I got the CV joints and changed them. I still have the problem. But when they changed the CV joints, they pointed out the bush that was worn. That's why I'm where I am now.
Thanks again everybody for the help so far
- x 1998
The Frip joint is Number 14 ....and it is a common joint to replace. (see my 1st post for the link).A worn out Frip joint will quickly lead to the destruction of the other "soft" joints of the lower suspension parts especially is you often drive on very dusty dry and unpaved/rough roads.
TBH I think you should have a better "diagnostic team" than a random tyre garage....
david2010C5
- x 3
Well, I can report back now. First, I'm grateful for everybody's help on this project.
On Monday I managed to track down the bush. On Tuesday morning I went in to collect it, and I asked them about the "frip joint" (number 14). They called it a ball joint and had one in stock, so I got it as well.
Earlier today I took the parts to a place I'd found about 7km from me, and they fitted them and did the wheel alignment. The bush was completely shot, and the bearings on the ball joint were shot too. I can definitely notice a difference in the drive.
So thanks again to everybody involved — I really appreciate it. Next month I intend to change the front tyres.
