Hi guys!
I’m experiencing a strange issue with my 206 1.4 HDi from 2004. All was well until a few months ago, when it gave an “airbag fault” and “passenger airbag deactivated” message on the center display. I now got time to take a look at it with Diagbox/planet (I set it to French language to accommodate for translation errors, not so uncommon), and it comes up as an intermittent fault about “capteur de sécurité”, which translates to “safety sensor”. No additional info or codes are given. However I’m a bit at a loss. I’ve studied the diagrams on SEDRE but there’s nowhere any component with that name.
Consider that my car only has the standard driver and passenger front airbags, no side or curtain ones. So I have no connectors under the seats nor any additional acceleration sensors. I tried shaking the looms around and near the plugs on the ecu and com2000 but to no avail, never been able to reproduce the issue. Sometimes it just pops up on its own. If I cancel the codes, it clears out and can be one day or a week before it comes up again, it often also clears on its own.
I’ve also heard that a weak battery could give these symptoms, but mine is about 3/4 years old and tests good with a battery checker, I don’t know if it’s worthwhile to replace it anyways.
Thanks in advance for any help!
Have a nice day
Peugeot 206 1.4 HDi intermittent airbag fault
dfabrici
- (Donor 2021)
- x 10
- x 8080
Re: Peugeot 206 1.4 HDi intermittent airbag fault
This type of intermittent issue often turns out to be a dirty connection somewhere in the circuit. I'd suggest you disconnect the battery and then go through all the fuses checking for cleanliness and stability, then unplug and check all the plug pins and socket connectors for dirt/corrosion. Give them a spray of contact cleaner and reassemble. I'd do all the plugs around the fusebox as well as any others in the airbag circuits Good luck
dfabrici
- (Donor 2021)
- x 10
Hi! Thanks for answering!
I guessed as well and will make a “cleaning tour” of all the connectors.
I was however wondering if anyone of you had any ideas about which component it could be fussing about, to “focus” my research a bit more, to confirm whether there could be corrosion or similar on more specific pins.
Thanks!
Thanks!
PaulC5
- x 670
Can you list the fault codes that you are cancelling and their English definitions.
- x 7163
This may not be much help, but I suspected from the description that "capteur de securite" had a reasonable chance of being a "crash sensor".
AI came back with this.... "A capteur de sécurité (safety sensor) in an airbag circuit is a type of sensor that detects collision forces and helps determine whether the airbag should deploy. It works alongside other sensors to ensure that the airbag system activates only under appropriate conditions, enhancing passenger safety during an accident.
repairmysrs.com
elprocus.com
I have no direct experience of your Peugeot 206 but do have experience of replacing the side impact crash sensors in a Renault Clio to correct an airbag light on fault. On the Clio they are mounted on the inner sill inside the vehicle, and can be subject to water ingress. as a result of soggy passenger footwell which is a fairly common occurrence in the Clio.
There may also be a frontal impact crash sensor in the vicinity of the bonnet catch.
The successful conclusion is here... viewtopic.php?p=790922#p790922
These are the side-impact crash sensors as applicable for the Renault Clio of 2003 vintage which sorted the Airbag light on for me. Wouldn't be too surprised if the Peugeot 206 2004 had something very similar.
repairmysrs.com
elprocus.com
dfabrici
- (Donor 2021)
- x 10
Hi all
Thanks so much for your contributions.
Later I’ll send a screenshot of the pp2000 screen in English.
I also came to the conclusion that it could be something like that, however from what I gathered from Servicebox exploded views, there is no such sensor in my car, the side ones are present only in case of side airbags, and it looks like the main front sensor is integrated in the airbags ECU (that has indeed a front pointing arrow on it)…
dfabrici
- (Donor 2021)
- x 10
Hi all,
As promised here a few pictures of the fault codes, in French and in English. I also took a picture of the ecu config. No live data is available from the airbag ecu.
Thanks in advance!
Davide
Thanks in advance!
Davide
- x 7163
Can't offer anything specific on the Peugeot 206 Davide. I have sorted airbag light on with the Renault Clio, where the usual suspects are the wiring connectors under the seats, and the side-impact sensors, and the Nissan Micra where the solution proved to be a replacement SRS ECU from a scrapyard.dfabrici wrote: 07 Sep 2026, 08:03 I was however wondering if anyone of you had any ideas about which component it could be fussing about, to “focus” my research a bit more, to confirm whether there could be corrosion or similar on more specific pins.
Thanks!
On the Clio, the termination of the wiring at the seatbelt pre-tensioners is a little plug which pushes into a socket on the pre-tensioner itself. These can become loose through movement of the seat and may simply require pushing in to re-make a positive contact enough to pass the SRS ECU's initial self-test.
