Peugeot 2008 Pure Tech
Sm8511
Unread post by Sm8511 »
I have owned a 2008 Peugeot Pure Tech since Aug 2024 (2022 model). The sat nav worked fine for 12 months. Unfortunately it has stopped working and seems to be a problem with the bluetooth connection. It does not work with Android or Apple phones.
Any idea how to resolve?
x 8149
Re: Peugeot 2008 Pure Tech
Have you tried pairing a different phone? :)
owl
x 15
Unread post by owl »
Hi! Try to delete the bluetooth pairing completely, then restart both the phone and the car. Try to add from begining.
Also please test apple carplay / android auto separately.If possible, connect the phone using a USB cable.If wired carplay/android auto works but bluetooth doesn’t, the problem is most likely related to the bluetooth connection.
Sm8511
Thanks. Tried all that. I am convinced it is the bluetooth connection. Any further advice will be great
Sloppysod
x 398
Unread post by Sloppysod »
Have you removde the 'Car' from the phone connection lists, restarted your phone, then tried to connect again?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Sm8511
Yes. Managed to remove the phone and then add it again. All to no avail.
