Huskyxantia
x 872
Unread post by Huskyxantia »
The fluid is horrible , the pouch set up is quick disconnect the old one them connect the new then diagnostic session to reset the level, 10 min job if l
All goes well, the refill of the tank with fluid I used a battery oil pump last year that worked a treat.
:-D
x 2316
Unread post by MattBLancs »
Huskyxantia wrote: 28 Aug 2026, 19:43 The fluid is horrible , the pouch set up is quick disconnect the old one them connect the new then diagnostic session to reset the level, 10 min job if l
Yes I remember you'd said about a pump for this task - for me the mess was disconnecting and reconnecting the hose connections, that's where I came in contact with the fluid.
The filling kit has a lid with a hose tail, last time I did this job I learnt the hard way that it also has a small breather hole (allowing air into the bottle (as the fluid leaves) - though if you try and encourage the fluid out (i.e. give the bottle a little squeeze) you very quickly revert the "air in" port to a "fluid out" port!! Do not recommend :-D
Huskyxantia
x 872
We all learn hard ways and that's one of the best ways I think
:-D
x 8300
MattBLancs wrote: 28 Aug 2026, 11:39
Huskyxantia wrote: 28 Aug 2026, 10:46
MattBLancs wrote: 28 Aug 2026, 09:49 Hmmm, completely silent red 308 this morning - no radio, sat Nav or parking sensor noises at all!?!
Odd , any idea whats caused it ?
I think it was working yesterday, so the only thing that could have upset it is the Diagbox session yesterday afternoon.
I had that happen on my Picasso Matt... It magically fixed itself when I threatened it with a Diagbox session ;)
x 2316
CitroJim wrote: 29 Aug 2026, 05:46
Many Diagbox threats have been made, it's not scared into action by that unfortunately!
Will get it plugged in over the weekend hopefully :)
Huskyxantia
x 872
I Finally popped my 308 on the maxicom yesterday
Soot content apparently 1% ... so all them regens may of been heat wave related.
:-D
x 2316
Radio function returned today (no Diagbox, or threats needed!)
x 8065
Did you take your earplugs out then Matt? :rofl2:
x 2316
mickthemaverick wrote: 29 Aug 2026, 11:12 Did you take your earplugs out then Matt? :rofl2:
They must have been soluble ones that dissolved by themselves overnight - all eight of them as whole family curious on board when it gave us the silent treatment :)
Huskyxantia
x 872
hands up whos got rain ....... grrr , well we need it my jobs can wait . good to hear your cars back to its normal audio self (the hear bit wasnt a pun btw)
:-D
x 2316
Huskyxantia wrote: 29 Aug 2026, 14:20 hands up whos got rain ....... grrr , well we need it my jobs can wait . good to hear your cars back to its normal audio self (the hear bit wasnt a pun btw)
On and off here, but just enough to be annoying :)
Oh I like a good pun, don't hold them back!
ozfrog
(Donor 2026)
x 75
Unread post by ozfrog »
That’s very interesting.
My audio system is still not working properly, but I can usually get it to work at least for receiving a Bluetooth signal so that I can stream from my phone etc.
But twice now, it has stopped working completely and eventually the first time, it started to work again, but I don’t know what I did to make it work. However, I’m fairly confident that at least the more recent time it stopped working was immediately after I had been using DiagBox because, once again, my beloved 307 threw up an engine warning light, and I needed to find out what the problem was this time.
This engine light problem was a week ago, but I didn’t get to DiagBox until Thursday. Today is Monday, and my audio system is still on the blink. I can usually fool the audio system into working again by inserting a CD which turns on the whole system and automatically selects CD as the source. But both times that the system has stopped working after what I suspect is a DiagBox session, my foolproof method is no longer foolproof. But like I said, I don’t know what I did last time to get it working again.
Cheers,
Andrew
x 2316
ozfrog wrote: 31 Aug 2026, 07:21 That’s very interesting.
That's odd!
From memory, not on a 307 but on the cars I've plugged in, you can interrogate the radio itself and it can log faults - sure I've seen faults about the (amplified) aerial, the MFD screen, steering wheel controls, parking sensor ECU, etc all raised by the radio itself. There's also Actuator Tests (think you can have it produce a sound on each speaker individually) so a play with that might be worthwhile too.
I'm putting my fault down as "just a glitch" and effectively fixed by IT repair option 1
x 2316
MattBLancs wrote: 16 Nov 2025, 14:00
Huskyxantia wrote: 16 Nov 2025, 12:37 Good luck with the other car Matt
Thanks Husky, back on it in a mo.
Here's the wiper spindle problem I found:
Ah, can't edit this old post - realised I'd deleted the first video and have made a longer one with the conclusion:
Will take the "new" (red) 308 wiper motor out at some point as I'd say it's noticeably slower than it's predecessor - so will give it some lubrication
x 8300
Pleased your radio is now working again Matt :D
