Peugeot 308 1.6HDI 2013
Danilov
x 7
Unread post by Danilov »
Hi all,
I recently did some work on driveshaft so needed to drain gearbox oil. Refilling it through breeder valve at top of the box. Long story short I took battery out for 2 days. After connecting it noticed that my folding mirrors stopped folding when locking the car. Didn’t bother me much at the time but then noticed that even when cold start in the morning my fan started and if I shut the engine still cold, fan continues to run. Pulled my ThinkDiag and there you go - lost communication with driver and passenger side door modules and no signal from ambient temp sensor. What I’ve done so far. Reset BSI following procedure explained in this forum a few times, no luck. Ambient sensor is in driver side mirror, took sensor out and was measuring 1.2k out of circuit and responding to temp changes( NTC type) supply to it 5v when out, when connected about ~1.1v, 1.2V. Here is picture of the scan faults after BSI reset
Danilov
x 7
Re: Peugeot 308 1.6HDI 2013
… so need to find some diagrams to see how BSI communicate with door modules and connection to temp sensor. Any advise appreciated. Thanks
x 1944
Before doing any of that, try a BSI reset first.
viewtopic.php?p=601679#p601679
Danilov
x 7
Paul-R wrote: 21 Jul 2026, 09:26 Before doing any of that, try a BSI reset first.
“…What I’ve done so far. Reset BSI following procedure explained in this forum a few times, no luck!”
Been there, done that. Here is my VIN: VF3**************[VIN obfuscated, can be read by forum staff].
penners11
x 6
Unread post by penners11 »
If my memory serves me correct there is a procedure to be for removing battery and refitting if battery. I will have to scan and copy to a pdf then post it here tomorrow.
x 5677
Danilov
x 7
All sorted out now but lesson learned, disconnecting battery in Peugeot vehicles could randomly change setting in different modules. In my case loosing temp reading was not the end of the world by itself if it didn’t disable regeneration. So for you guys before disconnecting battery in Peugeot vehicles follow the procedure. That’s lesson I learned.
