x 1487
Both LUK and Valeo list 2 sets for this engine, with the change over at RP 14469 (20 06 2016). Both 250mm, so no idea what the difference is!
Yours was reg 27 05 2016 so should be the earlier one - Valeo kit 837396 (4 part) / LUK 625 3203 33 (3 part, ex flywheel - only seems to list one flywheel 425 0853 10).
If only we still had access to service box and could look up the OE part numbers. And prices for a laugh :twisted:
x 1070
Unread post by Rp0thejester »
MattBLancs wrote: 13 Aug 2026, 06:11
Rp0thejester wrote: 12 Aug 2026, 23:41 May I suggest online automotive parts, I ordered a set of front springs for my C8. They contacted me a day later saying they wouldn't fit and I needed different ones. Good checking on their behalf or I would have had springs for a C8 Corvette.
These folks?
https://www.onlineautomotive.co.uk/
Ah, not come across them, I'll keep them in mind - thanks :)
They do list a clutch kit, LUK for my car and pleased to see it's 250mm as expected:
https://www.onlineautomotive.co.uk/peug ... -and-parts
Seems a good chunk more expensive (£556.49 for clutch, pressure plate and release bearing/slave cylinder - Vs £475 for the same plus DMF I've just bought. (Valeo branded)
Are they one of these endless different discount places, like Autodoc?
They tend to have a sale on near bank holidays. Luckily for me there parts department said no and refused to send them as they wouldn't fit, so at least saved me the p&p sending them back.
ozfrog
(Donor 2026)
x 76
Unread post by ozfrog »
MattBLancs wrote: 09 Aug 2026, 20:17 Yes, a clutch change should be doable for me. Just pricing them up.
I don’t want to derail your thread, but …
Does this car have a dual mass clutch?
And if so, will you replace it with the same? Or will you replace it with a standard clutch? In Australia, the clutch conversion kit is quite expensive, but it means that future clutch replacements will be a lot cheaper.
In both my early 406 and my 307, I opted for a single clutch. But I’m not convinced that I’m capable of doing the job, so I had mechanics do both cars. They were expensive jobs! But they were done by different mechanics.
The 406 was done by a person who knew Peugeots. The clutch was replaced in 2013 or 2014 and it is still perfect in operation.
The 307 was done by someone who is a good mechanic, but isn’t a Peugeot person. He said he was willing to learn about Peugeots, but the clutch on the 307 is really rough to use. It’s hard to take off from a standing start without the car shuddering.
I feel like a novice driver who has no idea how to drive a manual car! It’s the complete opposite to the 406. My hope is that the clutch will die quickly and that I’ll be able to get it replaced by someone who can get it working without shuddering. I don’t know if this shuddering is built into the replacement clutch or if it’s just a bad job of installing the clutch. Hopefully it isn’t built into the car having been changed from a dual mass clutch to a single mass clutch. I suppose only time will determine that. Or maybe I don’t know enough about the clutch to answer the question.
Cheers,
Andrew
ozfrog
(Donor 2026)
x 76
MattBLancs wrote: 10 Aug 2026, 13:12 I've been in some remote spots, …
Ha!
You don’t have a clue what “remote spots” really mean in your country!
Cheers,
Andrew
x 2342
Unread post by MattBLancs »
RichardW wrote: 13 Aug 2026, 22:09 Both LUK and Valeo list 2 sets for this engine, with the change over at RP 14469 (20 06 2016). Both 250mm, so no idea what the difference is!
The difference is an extra £70! :-D
Yep, both 250mm and from the pictures look the same (assuming no "stock photo" nonsense going on!
My RP is 14400 (Tuesday 12.4.2026 says https://www.mittns.de/core/orga-rechner-en/ )
Hurrah! That's what I've bought (2nd time round)
Indeed! thanks for your help :)
x 2342
ozfrog wrote: 14 Aug 2026, 06:16
Too late to worry about that! :rofl2: washing machines, gardening and all sorts of non-car related stuff slips in - all good!
308 : Yes it's a dual mass flywheel - most of the HDi engines are to my knowledge, as I understand it only the original 90 bhp 2.0 8 valve HDi being conventional solid flywheel. It's bigger brother the 110 bhp 8 valve and most other HDi = all DMF equipped.
I've kept it with DMF. Conversion kits not a lot cheaper than keeping it as Peugeot intended and to be honest I'd say most UK cars are unlikely to see their third clutch (as something else will kill them off, e.g. rust!)
Diesels make quite severe torsional vibrations between power strokes and my understanding is that at idle speed in particular these are pretty harsh for the gearbox to deal with.
I've done clutch changes in the past (including the 306: pull type that is a bit of a faff!) but the 308 is probably going to be the biggest job just given the amount of "stuff" in the way before I am pulling the gearbox off. Not sure if the subframe has to come off (it did on the C5 - ah, looking at the pictures, no it was just the crash bar frame thing I got away with, looking back:
x 2342
ozfrog wrote: 14 Aug 2026, 06:25
Ha!
Ha ha, very true!
Ok, definitely not "remote" but far enough that waiting for help Vs having a go fixing myself, I'd go for the latter
Huskyxantia
x 906
Unread post by Huskyxantia »
Take a few photos of all the cables , loom, and stuff that lays over the gear box , when my c3 was done my friends and me took the engine and gearbox out in one go, then all three of us undertook a task each thus getting everything done that was needed doing .
My experience with solid vs dual mass
There is a slight difference in power and if your like me you might feel a little vibration not much but I did , fuel difference, not much , life span solid will be longer , dual mass smoother as in drive , gear change, but I'd say the solid is a 8.5 out of 10 , dual is a 9, If I needed another clutch I'd go solid , if you tow stuff , solid all day .
:-D
x 2342
Huskyxantia wrote: 14 Aug 2026, 08:47 Take a few photos of all the cables , loom, and stuff that lays over the gear box , when my c3 was done my friends and me took the engine and gearbox out in one go, then all three of us undertook a task each thus getting everything done that was needed doing .
Yes, good plan with respect to lots of photos - Will do.
Interesting first hand experience - thank you :)
x 2342
Job one, done:
Reason: Image rotation corrected
x 2342
Pumped a tiny a little bit more red stuff off the top, minimal.
Underneath the spare wheel Adblue crystal central!
x 2342
Quick dump of photos text to follow. Quick summary:
quite a lot of surface rust underneath (surprisingly worse than the also 2016 and more mileage blue 308 SW was!) so a clean up, rust treatment and repaint on the cards.
Both front arch liners have had it.
Every fixing bone dry, not a hint of copper grease on the whole car!
Hub nuts did not argue with the meter long 3/4" breaker bar. 32mm socket.
Bolts and bracketry under bonnet fairly rusty heads but have come out, so far. Arch liners looking like it'll be a different story.
All that Adblue crystal mess removed from the boot well.
CV boots (MOT advisory back in May) look less awful than I'd have guessed (one new one on order, a stretch boot to try (new done it that way before!) but likely look out for some of the harder plastic type as longer lasting.
x 2342
Air filter looking decidedly old, that'll get changed.
Huskyxantia
x 906
Nothing like getting to known your latest car then digging around, get your own stamp on it . Nice set of photos too. And ive finally got the roof shut on my 308cc even though the temperature is back on the climb
:-D
ozfrog
(Donor 2026)
x 76
MattBLancs wrote: 14 Aug 2026, 07:36
ozfrog wrote: 14 Aug 2026, 06:16 I don’t want to derail your thread, but …
At least my 'derail' was about cars!
Firstly, thanks for correcting my terminology. I knew that calling it a dual mass clutch wasn't right, but I couldn't come up with 'flywheel'!
I wonder if your knowledge is wrong (I'm sure it isn't!) or if Australian 406s were equipped differently. I'm pretty sure that both of my 406s have the 2.0 litre, 8 valve, 90 BHP HDi engine. And when the earlier one of mine had its clutch changed, I had to decide whether to keep the DMF or convert. You have me pondering a few things now.
… UK cars are unlikely to see their third clutch (as something else will kill them off, e.g. rust!)
Is what I was once told true, that in the UK, you're never more than 100 kilometres away from the sea? If it is true, then I'm not so surprised about the rust problem. Here, people who live inland, like I do, are generally unwilling to buy cars that have lived in coastal areas for any length of time.
Congratulations! You just described my 307 to a T.
I've never even seen a 306 that wasn't an automatic transmission model! If you hadn't told me that you'd changed a clutch in one, I could have gone through life believing that the 306 only ever came out in automatic transmission varieties.
That's you?
Hmm, completely different to the image I had of you. And I'm not saying anything further on that topic!
Cheers,
Andrew
