Battery draining problem
gsc1ugs
x 3
Re: Battery draining problem
Unread post by gsc1ugs »
What have a done now!!!
I was going through the fuses and each time i pulled one to see if dim lights go off, i get to this big 60 amp checked dash, dim lights had gone off so i put it back no vehicle is not doing as it should, fuel level not showing, when opening door dash doesn’t light up until you put key in to ignition on, warnings like help unavailable, airbag failure warnin? Remote does nothing to the van and turns over wont start!!! Help please. 🙏
Fuse seems be F05. I plugged diagbox in and nothing is reading, been through fuses cant find a blown fuse in engine or off the bsi next to odb socket
gsc1ugs
x 3
False alarm!!! Id put the 60 back in wrong slot 😑
gsc1ugs
x 3
Ok ive been through all fuses, only thing that turn dim lights off was 5 amp 3rd from top but got lots of airbag warnings so it seems be ecu fuse
gsc1ugs
x 3
My mate got same van. So plugged my speedo on his, them lights stay dim lit on his but after 30 secs go out
Gonna fit back on mine and test but i dont think mine goes out im sure hence the problem, what ever device is that turns them out is the problem anyone know what that is?
is it the Rheostat? but on google thats for heater matrix
PaulC5
x 690
Unread post by PaulC5 »
Be aware that swapping a speedo it may take the mileage of the highest car. If yours was higher his will now show a higher mileage. If his was higher, yours will now show the higher mileage.
gsc1ugs
x 3
Well its been done and mileage stayed the same, its not a speedo fault when i plugged into his van mileage stayed the same
gsc1ugs
x 3
Ive been back to my mates same van, when door opens they illuminate both mileage and seatbelt light very dim and after 15 seconds, both go off same time! My mileage goes off buy the dim lights stay on, why?? Bare in mind i have tested my cluster on his van and they went off, totally puzzled
gsc1ugs
x 3
Anyone got any idea what look at? My mates speedo turns off dim light and mileage clock same time, mine turns off mileage but dim light stays on, whatever controls this must do both
gsc1ugs
x 3
I did a manual bcm reset, problem still here
Trickiedickie
x 14
Unread post by Trickiedickie »
Have any non standard electrical items been wired in?
Also if it has an after market radio installed try disconnecting it.
gsc1ugs
x 3
Did radio wasn’t that, nothing 3rd party but will check again
