Steering fluid
x 1938
Re: Steering fluid
What colour is the fluid currently in your power steering? Regardless I would only use LDS or DA just to be sure. Looking at specifications as best I can Pentosin CHF 11S is sort of compatible as it's synthetic (not mineral) and for power steering equipment but, like I say, go for the correct stuff.
If it's already green I would drain it out and use LDS/DA as you can't be sure that it hasn't been wrongly filled with the earlier Citroen fluid LHM which is mineral and green.
malwee1
Re: Steering fluid
Unread post by malwee1 »
I don't have any inside! but are you sure the Lds or da are the correct , not LHM (green one)?
x 1938
Re: Steering fluid
Absolutely!
malwee1
Re: Steering fluid
thank you
PaulC5
x 685
Re: Steering fluid
Unread post by PaulC5 »
The C5 X7 is well known for the steering rack to leak fluid at the pinion seal and also where the pipes join the pinion. Have a look to see if the fluid is being lost from that area (where the steering column joins the rack) with the fluid level being low.
malwee1
Re: Steering fluid
I will do that , thanks a lot 😊
