Strange wiper problem
Turfite
Re: Strange wiper problem
sorry I ment under the plastic cover I can move the magnet parts ok
Turfite
sorry the mechanism under the plastic cover
Estately
- x 22
Hi Turfite,
A couple of things.
The parts in the die cast case come apart easily, just take a photo before dismantling or keep one motor intact as a pattern to reassemble when cleaned and greased.
Your reference to a plastic cover has me stumped.
The shaft that the magnet sits on and has a worm drive at the end comes out of a circular metal case containing the windings and brushes of the electric motor.
I did not have to disturb mine so am not able to comment.
Sorry I would like to help, you could run it without the wipers and if the movement is jerky then maybe the electric motor is failing.
Andy.
A couple of things.
Andy.
If it can happen it will.
