rneg update
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
x 1942
Re: rneg update
@cmaranon, check your PM.
Spasoje123
Re: rneg update
Unread post by Spasoje123 »
Can you send me a link to the RNEG-R50b-R50.03 update?
x 1942
Re: rneg update
@Spasoje123 Check your PM.
Arbios
Re: rneg update
Unread post by Arbios »
Hello does anyone still have the li k
x 1942
Re: rneg update
Which firmware is it you want?
M4ns4lor
Re: rneg update
Unread post by M4ns4lor »
Good afternoon
Can I get the link to the newest possible version for my c5? It's 2010.
Currently running
rneg_D_R27bis_R27.01
Thanks in advance
Bart
x 1942
Re: rneg update
@M4ns4lor
Check your PM for a link to R50b.. It's not my link and I have no control over it. Usual disclaimers, use at your own risk, etc.
grofcilo
Re: rneg update
Unread post by grofcilo »
Hello,
I need RNEG R50b R50 03 update for C4 Picasso 2012. Can someone send me please?
Thank You
x 1942
Re: rneg update
Check your PM in 5 minutes. Same disclaimers as two posts above,
Easy
Re: rneg update
Unread post by Easy »
I would really appreciate a link to RNEG R50b (R50.03) firmware. Thanks.
x 1942
Re: rneg update
@Easy
Check your PMs.
lego741
New User
Re: rneg update
Unread post by lego741 »
Hi, I also need R50b R50.03, could someone please send me the link?
x 1942
Re: rneg update
Check your PM in 10 minutes for a link.
Note that this link was reported by Easy (just two above you) as follows "Thanks for the link, but those files are a bench-recovery kit designed for reviving bricked hardware via a serial/TTL or EEPROM programmer, not a standard consumer update package. A standard RNEG R50.03 (R50b) firmware archive, typically a 150 MB–250 MB, would be a .zip file. I just thought I would let you know what that link actually is."
Please post back your findings. The link isn't mine, I have no control of it and even less idea of whether it works!
Use at own risk, etc.
