I had B0100 on my ecu, i found a clean one matching numbers but someone said i need to just code / proxy align it
What they mean?
Airbag module question
- x 1487
Re: Airbag module question
It may be coded to the car, so the car's details need to written to the ECU. Proxi alignment is a Fiat thing which applies to Relay / Boxer vans. Don't know if you can do the airbag with a std scan tool.
gsc1ugs
- x 3
Ive got diagbox will that do it?
gsc1ugs
- x 3
Is telecoding similar/
- x 1487
Later versions will only do coding with a connection / sub to the Stellantis server.
gsc1ugs
- x 3
So when i plug this in whats going to happen?
- x 1942
What version of Diagbox software are you running?
What vehicle and year is this about?
- x 1487
What are you working on?
It may just work; or you may still have air bag light and / or other warning lights for other ECUs getting upset that the airbag is not sending the right data. Unlikely it will cause any permanent damage.
gsc1ugs
- x 3
7.85 diagboxPaul-R wrote: 13 Jul 2026, 17:21 What version of Diagbox software are you running?
Citroen nemo 2013 diesel
- x 1487
Nemo is a Fiat clone, so Proxi alignment might be needed. 7.85 might be able to do it without being online - you can only try!
gsc1ugs
- x 3
Ecu came plugged in no lights on and limp mode gone. Thxs everyone
