The joys of shopping online!
- x 8097
Re: The joys of shopping online!
Rough sketch of my first thought!! each handle has its own spindle with interlocking cogs?
- x 1940
My first thought is that it's simply a demo of two different spacings available to suit different lock mechanisms.
Vic Evans
- x 171
I find Amazon.fr are fine for most things & relatively easy to deal with if there's a problem. It also beats driving around to view an item in umpteen shops as most only stock a very small range.
Recent experiences are ;
Searching for a replacement for a 20 yo well known brand of cooker hood. I spoke to manufacturer's technical dept. who said my old model was obsolete & offered a similar looking & sized direct replacement. Looking at their website the noise levels were comparable with the old'un so I ordered one from Amazon rather than direct from manufacturer.
It turned our to sound like a jet engine on full chat & manufacturers tech. dept. didn't want to know when I complained.
Sent it back via Amazon & got full refund PDQ. No idea what would have happened if I'd bought it direct but no doubt problems.
Bought another make (Grundig) with lower stated noise levels & made the alterations to fit it.
Chalk & cheese with this hood's noise level totally acceptable.
Recently bought a wheeled cord-less strimmer from Amazon to save Mme's back. Reviews were pretty good & priced mid range.
It was rubbish & impossible to use without cutter blade digging in when push/pulled due to the geometry of thing & blade spindle came adrift with blade attached.
Sent it back with reimbursement to our A/C just hours after it was deposited at local post office with Amazon returns paperwork.
Lesson learnt & another, more expensive, unit with better geometry bought from Amazon which has turned out to be excellent.
Like Bezos or not, Buying from Amazon does give one confidence that problems will be amicably resolved & it beats the hell out of driving all over the place to view small & most times non existant stock.
- x 5673
Never had any problems with Amazon, also bought from Amazon in Germany, USA and Japan without any drama other than import duty from Japan, not Amazon't fault (DPD).
But as you mention Bezos is persona non grata and I limit my purchases to Kindl now, not a lot of choice in that unfortunately.
Vic Evans
- x 171
I agree about Bezos but I figure my & thousands of other's contributions to his wealth wouldn't exactly bother him if we shopped elsewhere so I bite the bullet, & say a quiet & hypocritical "thanks Jeff" each time I look at the enormous range of products available at the touch of a button, delivered quickly & cheaply with their Prime system. Seriously, where else can you get next day delivery on a 5 euro item for peanuts & who wants to drive around shopping this weather?myglaren wrote: 09 Jul 2026, 11:17 Never had any problems with Amazon, also bought from Amazon in Germany, USA and Japan without any drama other than import duty from Japan, not Amazon't fault (DPD).
I just ordered 10 electric roller shutter fixing thingies from a stockist, cost 15€ with delivery 10€ taking almost 2 weeks.
Makes Amazon Prime a no brainer if they stock something you need.
- x 2341
That'd work, but you'd have the odd situation of the opposite handle going up, when you pull the handle on your side down!mickthemaverick wrote: 09 Jul 2026, 08:23 Rough sketch of my first thought!! each handle has its own spindle with interlocking cogs?![]()
- x 2341
Yes, think this is most likely explanationPaul-R wrote: 09 Jul 2026, 09:13 My first thought is that it's simply a demo of two different spacings available to suit different lock mechanisms.
- x 2341
Good thoughts and I agree with Amazon being a bit of a "necessary evil" for want of a better term!
I've never had "Prime" but usually check prices a few spots, including Amazon, before a reasonably costly purchase is made.
Ok, I tell a lie, I can't help but look even when it's under a fiver too!
eBay is often the cheapest source and generally has a "the buyer is always right" approach which at least gives confidence on getting money back.
It surprises me how often I've looked up an eBay seller's own personal website only to find the same products are more expensive from them direct than from them through eBay - not just when eBay is offering a discount code either. Very odd!
deuchebleu
- x 21
These locks are quite common on new builds. The handles are on separate spindles but not interlocked. I had them on a new build I bought in 2008, they were a pain in the proverbial as it was soooo easy to lock yourself out. Basically when the door is not locked you can't turn the outer handle without the key. The theory is, as explained to me, that it's for security in built up areas in that if you come in with the key then close the door nobody can then follow you in as the outside handle is locked. My house was in rural North Yorks but this was a national builder. I rang up the manufacturer and wanted to buy matching outer handles that would operate on the same spindle as the inner handle.Had a very interesting conversation with a salesman and he sent me two outer handles, front and back, gratis. I suspect I was not the first. Bliss, you could go out in the garden without constantly carrying the key in your pocket.MattBLancs wrote: 09 Jul 2026, 20:48Yes, think this is most likely explanationPaul-R wrote: 09 Jul 2026, 09:13 My first thought is that it's simply a demo of two different spacings available to suit different lock mechanisms.![]()
- x 2341
Interesting!deuchebleu wrote: 09 Jul 2026, 22:10These locks are quite common on new builds. The handles are on separate spindles but not interlocked. I had them on a new build I bought in 2008, they were a pain in the proverbial as it was soooo easy to lock yourself out. Basically when the door is not locked you can't turn the outer handle without the key. The theory is, as explained to me, that it's for security in built up areas in that if you come in with the key then close the door nobody can then follow you in as the outside handle is locked. My house was in rural North Yorks but this was a national builder. I rang up the manufacturer and wanted to buy matching outer handles that would operate on the same spindle as the inner handle.Had a very interesting conversation with a salesman and he sent me two outer handles, front and back, gratis. I suspect I was not the first. Bliss, you could go out in the garden without constantly carrying the key in your pocket.MattBLancs wrote: 09 Jul 2026, 20:48Yes, think this is most likely explanationPaul-R wrote: 09 Jul 2026, 09:13 My first thought is that it's simply a demo of two different spacings available to suit different lock mechanisms.![]()
Yes, I'd need one of those external key safes if was lumbered with one of those!
A lot of complexity for something that does the same as this type: Where the outer isn't really a handle, more a fixed err, "spoiler" as far as the advert describes it, to push/pull the door open/closed.
My neighbour had one of those fixed spoiler handles when had his front door changed, it didn't stick around long! Very annoying.
