I'm looking for some technical advice regarding a persistent DPF warning on my 2012 Peugeot 3008 1.6 HDi.
Symptoms
- "Risk of particle filter clogging" warning appears intermittently.
- Vehicle drives perfectly with no loss of power.
- No limp mode.
- Warning sometimes disappears by itself after the vehicle has been left overnight.
Diagnostics
I've recently installed Diagbox 7.57 with a Lexia interface.
A full Global Test completed successfully and the only engine fault present is:
P1490 – Particle Filter fault
No other engine faults are present.
Live DPF Data
With the engine running:
- Calculated soot load: approximately 0.44 g
- Estimated ash load: approximately 26 g
- Differential pressure across the DPF at idle: approximately 3 mbar
These figures suggest the DPF is flowing very well and is not physically blocked.
Other Information
- The vehicle is still consuming Eolys additive, indicating regeneration attempts are occurring.
- The engine starts instantly and runs smoothly.
- No excessive smoke.
- Fuel economy appears normal.
- Engine performance feels completely normal.
Diagbox Observation
Within the diagnostic information I also noticed a parameter reporting pre-heating glow plugs: non-activation.
As the engine starts immediately from cold, I'm unsure whether this simply means the ECU isn't requesting the glow plugs, or whether a glow plug fault could prevent regeneration while still allowing the engine to start normally.
Current Thoughts
Given the very low soot loading, modest ash loading and extremely low differential pressure, I don't currently believe the DPF itself is blocked.
I'm beginning to wonder whether:
- a previous regeneration has left a counter uncleared,
- the additive (Eolys) ECU or DPF ECU requires an adaptation or reset,
- there is a historical fault causing the warning,
- or another regeneration prerequisite is not being met.
I'm continuing to investigate with Diagbox and plan to examine the additive ECU, regeneration history and any DPF reset/adaptation functions.
Has anyone experienced P1490 with such low soot loading, low differential pressure and an apparently healthy DPF? If so, what was the eventual cause?
2012 Peugeot 3008 1.6 HDi (SID807) – Persistent DPF Warning Despite Healthy Live Data
Chrismileham
PaulC5
- x 714
Re: 2012 Peugeot 3008 1.6 HDi (SID807) – Persistent DPF Warning Despite Healthy Live Data
How many miles has the car done ? Something to read that might help, this P1490 turned out to be a blocked dpf viewtopic.php?t=70122
Chrismileham
187000 miles. I do have it booked into a performance centre for a dpf clean. But there is no real sign of blocked dpf, and everything else suggests healthy filter, even though the risk of dpf clogging warning comes and goes.
