Good evening folks!
My 2017 Citroen C4 Grand Picasso II (1.6 BlueHDi 120hp) started screaming about not being able to see NOx sensor with error codes U029D87 & P220087.
This came up after updating engine ECU firmware through official diagbox (v9.268 newest at the time).
From reading around Google and forums I came to conclusion that NOx sensor is dead. Took off mine, from outside it was normal,
but I disassembled it and found lots of white crystals inside the chip.
I suppose that's probably salty water from puddles and that the chip is actually dead.
So I bought a new NOx sensor from HELLA for 200 Euro. Installed it and initialized it through OFFICIAL Diagbox with token.
I went in this menu order:
EDC17C60 - Repair - Pack Repair - Replacement Parts - Work On Emission Circuit - Replacement of NOx Sensor.
After that errors in Diagbox and SERVICE on dash went away and I took a long ride on highway with 80-120km/h for like an hour. It even turned on regeneration which I don't think it ever did before.
Now the new problem that I have is P220200 Heating of NOx Sensor - Availability time too long? What does this Mean?
It does not cause SERVICE on dash or anything but it comes up in Fault reading which is annoying.
Doing NOx Sensor Heater Test through Actuator Tests results in successful test with no faults.
Anyone had this issue before?
P220200 - Heating of NOx Sensor
ragingraven
- x 5
- x 5672
Re: P220200 - Heating of NOx Sensor
Your images are not viewable in the UK
You can upload images direct to the forum. There is a guide for that here
ragingraven
- x 5
ragingraven
- x 5
Problem has been solved!
Went around the wiring for the NOx sensor and there was a broken wire.
Everything seems to be working now.
- x 1938
Thank you for letting us know. Broken wires are not an unknown problem.
- x 2354
Hi, quick question - I know it turned out not to be your issue (thanks for confirming that too by the way!) but just to ask:ragingraven wrote: 15 Jun 2026, 21:41 NOx sensor is dead. Took off mine, from outside it was normal,
Was opening up the NOx sensor casing straightforward and do you think, reversible? (I.e. would it go back together again?)
Might be worth a spot of preventative maintenance to open it up and clean out the deposits??
ragingraven
- x 5
Heya, the NOx sensor lid was pretty easy to remove, so I don't see why not do maintenance regularly. Probably with alcohol though as you don't want to ruin it.MattBLancs wrote: 29 Jun 2026, 20:58 Hi, quick question - I know it turned out not to be your issue (thanks for confirming that too by the way!) but just to ask:
- x 2354
Hiragingraven wrote: 12 Aug 2026, 17:15Heya, the NOx sensor lid was pretty easy to remove, so I don't see why not do maintenance regularly. Probably with alcohol though as you don't want to ruin it.MattBLancs wrote: 29 Jun 2026, 20:58 Hi, quick question - I know it turned out not to be your issue (thanks for confirming that too by the way!) but just to ask:
Thanks for confirming - good info!
