Huskyxantia
- x 904
Nice bit of patch work there
Husky.
- x 2341
Quick summary, will update when I get chance:
Grey 308:
Left rear brake job completed: Hub nut 36mm, 300 Nm
Caliper carrier and guide pin bolts both 30 Nm then 35° angle tightened says Haynes (also states both are single use)
Reused but fresh thread lock compound.
Welding quickly brush painted, will grind welds back and paint properly soon.
Blue 308:
Wipers swapped (26 inch instead of standard 24 inch, Drivers and 16 in place of standard 18 inch passenger's. An experiment, seeking a reduced "triangle of doom"
Rear boot struts swapped. Boot end strut ball joints found to be corroded and severe pitting. Plenty of red rubber grease.
Hoping for a none creaky boot when off to the office tomorrow morning!
Grey 308:
Blue 308:
- x 8378
Good work Matt!
- x 2341
Boot gas strut bolts, possibly 9811552380
£40, each!?!?!?!
https://ebay.io/m/1WwTvq
Errrrrrrr I'll keep looking!
£40, each!?!?!?!
- x 2341
- x 8091
These people offer both M6 and M8 sizes, any good?
https://www.ebay.co.uk/itm/147351509818 ... 1875.m1851
Huskyxantia
- x 904
The ball head looks smallerMattBLancs wrote: 15 Jun 2026, 06:29 I suppose counts as "cheaper", £16 each
https://ebay.io/m/INTscX
Still looking!
Husky.
Huskyxantia
- x 904
Might be worth asking this car is being broken for parts
https://ebay.io/m/au2zjS
Husky.
- x 2341
Thanks Husky, I think I'm going to seek out (non-genuine!) new ones as the second hand ones may all be suffering from the same corrosion issues.Huskyxantia wrote: 15 Jun 2026, 12:09 Might be worth asking this car is being broken for parts
I'll pop a strut joint off again at time point and err, see how big my balls are
For the moment the boot is no longer graunching so the clean up and plenty of red rubber grease has bought me some time.
Blue 308 filled up:
490 miles covered,
£62.84, 159.9 ppl at Tesco Leigh.
= 39.3 l = 8.65 gallons
56.7 mpg.
Grey 308 delightfully free of brake grinding noises. Not ground the welds back yet but hopefully next weekend job.
Bathroom wall panelling sticking up,
Last full flag laid (3x2 IE 600x900x50mm = 64 kg!) from the drainage job.
Grass mowing done again.
IKEA rung up (as downstairs loo's tap I bought in November= chrome lifting!) and a replacement tap ready for me to pick up tomorrow. Pleased with that, hoping no need to call on the 10 year guarantee again!
Huskyxantia
- x 904
Husky.
- x 8378
Good advice from Betty Swollocks...
- x 2341
Summer weather, also featuring rumbles of thunder and
That was about half an hour, sun back out and back to sticky humid again rest of the day
- x 8378
Looks positively chilly Matt
- x 2341
Ha ha, I wish! The cooling effect of a good rain shower would be appreciated, but though it did cool things a touch (and overwhelmed the drainage as it does in proper cloud bursts!) temperature and humidity soon back up again.
Today lovely and sunny and so just the weather for doing nowt at all!
So obviously I've:
- Fitted my (birthday present) dash cams to the blue 308 with company and help from my eldest,
- Raised front end of the grey 308 seeking an elusive knock (not found) and checking front disks and pads (283mm dia, thickness about 25mm. New is 26mm, minimum is 24mm says Haynes, so quite literally half worn)
- Bulbs checked all round. Rear had a tail light out (twin filament 21/5w bayonet) and one of four high level (W5W / T10 "capless" 5w)
- Bushes and CV boots checked whilst front end up in the air. All ok.
- Then drilling our brand new, freshly plastered ceiling for a 150mm extract fan grille.
- Briefly in the loft to couple flexi hose between ceiling grille and external discharge louvre (no fan as yet, will do that when loft is less baking hot!) thought would minimise loft muck dropping down to bathroom below.
Huskyxantia
- x 904
The front end knock .. drop link sound or lower ball joint sound
Husky.
