C4 alternator fault
polophonic2025
C4 alternator fault
Unread post by polophonic2025 »
Hi all, I wonder if anyone could help me with a reversible alternator problem. C4 picasso 1.6ehdi stopstart 2013.
Car starts no problems, drives no problems and then reliably around 2minutes voltage drops from around 14.2V (lowest 13.8V highest 14.7V) to 12.8V (i.e. battery voltage). Illuminates error engine warning light, service light. After a few more minutes STOP and battery light - because the alternator no longer producing current. Turn ignition off, start car, back to normal until another 2 minutes.
Codes:
P1A84 PA19B
I guess the ECU is not getting what it wants from the alternator within some period of time after starting. This all points to bad alternator or perhaps bad voltage regulator in the alternator. But before I drop £1k on a new bloody alternator, I wanted to ask if anyone else had seen this problem and had any suggestions. Cheers!
x 8141
Re: C4 alternator fault
You will find some information here which may help: :)
https://www.engine-codes.com/p1a84.html
Sloppysod
x 397
Unread post by Sloppysod »
Hi, I can't find out anything regarding the fault code PA19B, did you use a generic diagnostic tool? It may be worth ticking some off the possibilities here.
https://www.quickstartcars.co.uk/knowle ... -explained
But rather than £1k, have you made enquires about getting it tested and repaired by a vehicle electric shop?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
PaulC5
x 697
Unread post by PaulC5 »
What happens if you put the headlights on, does the voltage then drop within 2 minutes ? If it is a smart alternator they reduce the voltage if the battery is charged up but if there is a high demand it goes back up. Only asking as there could be a battery fault.
ozvtr
x 253
Unread post by ozvtr »
polophonic2025 wrote: 21 Jun 2026, 12:21 C4 picasso 1.6ehdi stopstart 2013.
This is another start/stop failure.
By the sounds of it, I would suspect the start/stop ECU. The starter/alternators are relatively simple. These start/stop components are hideously expensive to replace, so you don't want to go about this willy-nilly. If you can't find any obviously damaged wiring or electrical connectors, then I would suggest that you "seek professional help".
The "alternator" does not have any rectifiers or regulator, the power management is done by the stop/start ECU.
polophonic2025
PaulC5 wrote: 21 Jun 2026, 13:29 What happens if you put the headlights on, does the voltage then drop within 2 minutes ? If it is a smart alternator they reduce the voltage if the battery is charged up but if there is a high demand it goes back up. Only asking as there could be a battery fault.
Voltage remains constant - within a few tenths - irrespective of load. So lights, AC, etc... Battery was replaced about 6 months ago and has been behaving well.
polophonic2025
Sloppysod wrote: 21 Jun 2026, 13:17 Hi, I can't find out anything regarding the fault code PA19B, did you use a generic diagnostic tool? It may be worth ticking some off the possibilities here.
My mistake - the code is P1A9B!
Sloppysod
x 397
Yes that works. As you already know.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
polophonic2025
Sloppysod wrote: 22 Jun 2026, 19:15 Yes that works. As you already know.
At this point I'm thinking the problem is that the alternator is unable to regulate output, which the ECU registers and then stops it from producing current. Or, there is a nw/wire connectivity issue. In any event I need Diagbox to diagnose. Off to the dealers!
polophonic2025
I have continued to do some exploration of this issue. An independent garage has diagnosed failing alternator and quoted £1800 to replace. Gulp! I can see new and reconditioned units for sale. Has anyone done this job themselves? If I replace like-for-like is any coding required?
shtu
x 78
Unread post by shtu »
polophonic2025 wrote: 29 Jul 2026, 11:32 An independent garage has diagnosed failing alternator
It's likely they are correct (but near-impossible to confirm remotely). It's most likely the slip rings and/or brushes are worn out.
I've done the job on a Berlingo, which is -similar-. Really, only you can judge if you have the skill and tools to do the job yourself. Like most jobs on Citroens, it's unnecessarily awkward. Access to get the alternator out and back in is the biggest issue, there's a lot of stuff above and around it that will require dismantling.
I'm not aware of any coding being necessary.
