Hello,
I have a Peugeot 508 2012 with RT6 / eMyWay / WIPNAV+.
Current firmware version: RNEG2.05.C.11
I would like the safest upgrade path.
Could someone please advise whether I should go directly to 2.86B or use an intermediate version first (2.80 / 2.85)?
I would also appreciate a known-good USB package (not RNEG/MyWay by mistake).
I understand I should back up my configuration first with MiraScripts.
Thank you.
Is it okay to go from 2.05 to 2.86 immediately?
vulchaka
- New User
- x 1901
Re: Is it okay to go from 2.05 to 2.86 immediately?
Simple answer - no. Really not advisable.
My first question is why do you want to update? Are you experiencing a problem of some kind?
As you can see on the accompanying diagrams taking 2.05 past 2.21 means that you will lose some or all of your configuration. The official answer is to use Diagbox to connect to servers in France to download the vehicle's configuration/calibration. Mirascripts can do the same by saving the configuration before you start updating to a pen drive. There are no guarantees on this though. You do it at your own risk.
If you decide to update I have 2.31, 2.71, 2.77, 2.80, 2.85 and 2.86 as an ISO to burn a CD. I also have 2.21, 2.37 and 2.86 to put on a USB stick.
Sadmir
Hello, I also have RNEG2.05.C.11.Paul-R wrote: 24 Mar 2026, 20:05 Simple answer - no. Really not advisable.
Can you send me the latest maps that I can install on this firmware?
- x 1901
Hello. Sorry I overlooked your request here just tacked on the end of this thread. Check your PM in a few minutes.Sadmir wrote: 03 Jun 2026, 16:16Hello, I also have RNEG2.05.C.11.
Not sure it will work given how early your firmware is but - here's hoping!
pedrocaldas
Most people advise against going from original software to the last version. Some report bricked units, bricked sd cards and functions, mainly a bluetooth calls echo.
I've done it because idgaf, (2.05 to 2.86b) and it went 100% perfectly! Not even the bluetooth echo.
Do at your own risk, if you have the guts to do it.
- x 1901
And yet other members here have posted that they did get the Bluetooth echo, had the wrong marque logo, etc.
