3008 hybrid4 2013
Pepe autotechnics
- x 8
3008 hybrid4 2013
Hi wonder if you could help, I have a Peugeot 3008 2L diesel hybrid 4 2013 and I have gearbox oil coming out of the breather pipe on the reduction gear, it has the correct oil Total 75w-80 and the correct amount 0.7 of a Litter after a run I get droplets of oil coming out of the breather pipe on the reduction gear, there are no faults in any hybrid ecu’s and the electric cooling motor works ok and battery fan for hybrid system and all the hybrid system works ok no noises and drives fine, any ideas why I am getting oil out of the breather??
- x 8040
Re: 3008 hybrid4 2013
Could you post a picture of the breather you are referring to?
Pepe autotechnics
- x 8
Hi you can’t really see the breather it’s at the top of the reduction gear, you can only just see the pipe from the breather I will send you a pic of the reduction gear from diagbox!!
Pepe autotechnics
- x 8
Mick I posted a photo of where the oil breather is, and that is where the oil is coming from on this 3008 hybrid4, a short rubber pipe attaches to the top of that breather and goes up above the reduction gear and oil weeps out of the rubber pipe, do you have any ideas, I would greatly appreciate your help!!
- x 8040
I am afraid I am not the man for this as I have only ever had one hybrid, a Prius, and so know nothing about yours. However off the top of my head I wonder if the oil is getting overheated and expanding up the breather a bit?
Pepe autotechnics
- x 8
Ok many thanks if you get any other ideas or suggestions please let me know!!
Sloppysod
- x 384
mickthemaverick wrote: 28 May 2026, 20:25 .........However off the top of my head I wonder if the oil is getting overheated and expanding up the breather a bit?![]()
Following on from Mick comment, rubber does deteriorate over time, especially when around oil, and as you car is 13+ years old, could the oil just be seaping through the rubber?
Stu
Pepe autotechnics
- x 8
No the rubber is ok, I seem to have resolved the problem by moving the rubber pipe higher up and it seems to be ok!!
- x 8040
Well done, here's hoping it lasts!
