Wow, thanks for answering !
By the way, I managed to have a look behind the steering wheel. I've found 2 rubber grommets but when trying to pierce both ofthem with kind of a needle, the tool is blocked shortly after. As if there is no way to pass through without drilling.
Did you drill through ? Maybe my car model is a bit different?
Regards.
Gab
C5 X7 amplifier power cables, trunk ground point
gab24
- x 5675
Re: C5 X7 amplifier power cables, trunk ground point
Can you pry out the grommets and see what is behind them?
gab24
Acces is realy difficult. I'have done this for the lower one.I saw grey foam (thin) and behind something hard to the touch (with a big needle)
raqall
My car is Left-hand-drive, 2.0 petrol.
Take a look: the cable I'm holding with my thumb is the one leading to the amplifier, you can see how it enters the firewall grommet.
I also took pics of how I installed the fuse, maybe this brings any value to you (in the ECU compartment, I've removed battery cover and the ECU cover to take the pics)
I don't remember if I had to drill, I think the grommet is quite thick so its not really possible to pierce it with a needle, maybe try removing it with pliers first to take a look.
gab24
Many thanks for the pictures!
I'll look at that soon.
Again many thanks for the time you took to respond to such an old post, and so quickly!
raqall
Thanks! and good luck
Feel free to post further if in doubt.
gab24
Hi, after checking my model doesn't have this gromet. (Hdi160 exclusive).
Anyway I managed to pass my cable using the method used in this video :
Maybe this info might help someone.
Many thanks to everyone answering to my messages !
