Citroen c3 2022 infotainment update problem
This section is for information and posts relating to Audio Head Units, and Navigation Systems
Sinzu
Unread post by Sinzu »
Ive updated the infotainment screen via USB through the official citroen app on windows11 but the upgrade was stuck at 54% for 60min , ive unpluged the USB and now its stuck in this screen.
HELP!
x 8113
Re: Citroen c3 2022 infotainment update problem
I've moved your post to the right section of the forum :)
Sloppysod
x 396
Unread post by Sloppysod »
What size USB stick did you buy, by default Windows 11 formats anything bigger than 32gb as ntfs, not Fat32.
See here to format bigger drives https://www.howtogeek.com/316977/how-t ... n-windows/
Have you seen these instructions, https://www.uktechhub.com/wp/wp-content ... System.pdf
If the following message appears « update failed »
- Remove the USB stick
- Stop engine
Disconnect the vehicle battery
- Wait 5 minutes
- Reconnect the vehicle battery
- Insert the USB stick
- Start the entire procedure again with USB stick.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
