DS3 high pressure petrol fuel pump
At my whits end
Unread post by At my whits end »
Hello everyone .. I’ve got a h/p fuel pump issue , I have replaced it and the low pressure one in the tank but it doesn’t seem to want to draw fuel . I have tried the reset method and still no joy . Also tried to purge / prime the h/p pump by loosening the nut of the fuel rail but still nothing any ideas please
x 8166
Re: DS3 high pressure petrol fuel pump
You need to isolate which pump is failing as its highly unlikely both have failed. If you disconnect the feed to the HP pump, put it into a bottle and turn on the ignition do you get fuel delivered from the pipe which you placed in a bottle? :)
At my whits end
The high pressure pump is new not rebuilt .. I don’t seem to be getting fuel up to it although I can hear the tank pump running
x 8166
Logic says that if the tank pump is running but not sending fuel down the line then it possibly has a blockage in its intake? :)
At my whits end
Thank you for your input I’ll check that tomorrow had enough of scratching my head …
PaulC5
x 717
Unread post by PaulC5 »
A stupid question, but is there enough fuel in the tank ?
