DIY Car Maintenance with function over finesse!!
x 8085
Re: DIY Car Maintenance with function over finesse!!
Had a minor issue yesterday with the stong winds overnight. The cover on the MX3 was lifted off from the back and blown over and onto the road but the front clips held on and stopped me losing it altogether. On examination I found the two rear clip loops had failed by ripping out the stitching and in one case ripping the actual cover:
Failed stitching
Failed stitching
The ripped cover
The ripped cover
The attacments are supposed to look like this:
The undamaged front link
As you can see from that, the manufacture involved stitching the holding loop into the edge of the cover. Since that resulted in one of the loops pulling right out and another ripping the cover it seemed to me far more logical to attach those loops robustly to the draw cord which goes round the entire cover and is pulled tight holding the cover underneath both bumpers. So I came up with this method:
Split ring around cord
So these rings will then be linked to the ties which each wrap round a spoke of the wheel,
The easy fit and release links
thus holding the draw cord to the wheels without putting any stress on the stitching or even the material as it had been:
The original connection
Now the drawcord will take the strain at all four points as well as being drawn tight around the car. Hopefully that will cope with any future gales that come our way!! :-D
John Pankhurst
(Donor 2026)
x 40
Unread post by John Pankhurst »
I'm a bit of a fiddler and one of the jobs I've been puzzling about is the lack of reversing lights on Ted my Morris Minor traveller. I've done the same to both my Commer campers which was an easy job as there is a spare place on the gearbox for a switch ( same g. box used on the Rootes saloons) but no such luck on a Minor box.
So I had a thunk and didn't want to simply wire in a toggle switch on the dash so dug out my spare box to investigate. There is a detent ball and spring on the reverse gate which is easy to remove by way of an external plug, so I started searching for a suitable switch to replace the ball, spring and plug. After a few false starts (couldn't find the correct thread switch) I came across Reliant stop light one that fitted perfectly.
The first attempt worked perfectly but as I had to re-cut the thread the the result was too shallow and tightening almost stripped it completely.
The second attempt was worse and the switch snapped in half but then I found the Reliant one
I'm waiting for a couple of round white LED units to arrive and will mount them with the same surrounds as the other traveller tail lights and will put up some pictures to show the final result.
Bench test proved the concept
Thanks for reading
John
John Pankhurst
(Donor 2026)
x 40
After a bit of a bursitis induced lay off Ted the traveller has working reversing lights
Made from a couple of screw top plastic containers painted black and LED units fitted to Morris traveller rear reflector mounts.
Nice and bright so other traffic should be able to see what I'm doing :)
x 8085
Further Mazda flat battery issue today. It has been a fair while since the MX3 had a run, and on that occasion it needed a jump start to get home, so I charged the battery off the car refitted it and have left it for the last few weeks. Stupidly I forgot to check the alternator which had been OK the last time i had trouble. This time though it is not OK and hence a new one is now winging its way to Hertford. Hopefully I'll get it fitted over the next few days and all will be well!! :-D :-D :-D
x 8085
In view of my deterioration in health nothing further has happend to the MX3 until yesterday. I decided that having bought all the parts for the outstanding work on both cars I should bite the bullet and ask my mate and former business partner to come and do the work for me as a paid job.
The parts I had assembled were:
MX3 all new parts:
Alternator
Water pump
Timing belt kit with tensioners
Air filter
Oil filter
Fuel filter
Coolant
Engine oil
Subaru
Oil filter
Engine oil
(I had completed the rest of its service before I got sick)
So yesterday my mate arrived at 09.00 and after a quick coffee we set about jump starting the MX3 and getting it onto the ramps on the drive. That meant SWMBO had to get her car out and she accepted that it may not be back in on the same day!!
As it is now with o/s front wheel and ramp in temp place for extra safety while waiting. Car actually supported on the axle stands.
Well it hasn't gone back yet due to three seperate problems that arose during the work, firstly the alternator charging stud is 13mm where the original had been 10mm so the spade terminal on the charging lead will not fit. Of course sods law dictated that I had 7 different sizes in stock but no 13mm - one order to Amazon for delivery today.
The new alternator
The new alternator
The spade that was too small
The new spade to be crimped onto the lead
Secondly the timing belt kit I had turned out to be wrong, which we hadn't opened until the strip down was complete! I had triple checked the compatibility on the website before ordering so when it arrived back in April I simply put it on the shelf to use when I recovered. On looking at the kit it had Gates part number K015273XS where as the correct one is part number K015274XS so I assume it was a picking error on their side!! I spent an hour trying to track down the correct one to collect and use yesterday but to no avail. The best I could do was one for me to collect today, which I have now done.
Wrong part number
Wrong part number
Wrong kit
Wrong kit
Correct part no
Correct part no
Correct kit
Correct kit
Thirdly having had to stop work on the timing Dave set about the rest of the service work, replacing the filters, oil change and install new water pump, which is where it all went wrong again!! The metal water bypass pipe connecting the heater return back to the water pump had corroded to the point of not being resealable with the push fit O ring seal as designed. I am currently looking for a complete replacement pipe but so far I have only found a similar one from the MX5 which we may be able to fabricate a replacement end for my pipe from. Watch this space!!
Water pump
Water pump
The wrecked joint (now bodged until proper fix available)
So at that point we realised it wasn't our day and shut the bonnet and the garage door to hide the state of it as in the picture below, note the chair which is where I had to spend 85% of the time only getting up to find something for Dave or make a loo trip!!
Hopefully we will get the job finished on Monday or Tuesday weather permitting but the pipe will be an outstanding job methinks. :-D
The garage as we have now left it
x 8365
Oh dear Mick, not the kind of automotive 'adventures' you want to be having right now :( Here's hoping all will soon be nicely resolved...
x 8085
I am pleased to say all the issues we ran into on Friday were resolved today, new pipe joint for the bypass, new spade for the alternator and correct belt installed. All filters were then changed and new oil and new coolant added to make the car as good as it can be now. So now to think seriously about selling it to save the £300+ tax it costs me to have it parked on the road!! :evil:
Following that success we did an oil and filters service on the Legacy and then pronounced my fleet fit and well!! :-D
x 8365
Excellent news all-round Mick but yes, agree on the cost of VED just to have it spending unproductive time on the road...
Maybe swap it for a small tax-exempt model perhaps?
x 8085
CitroJim wrote: 17 Jun 2026, 06:12 Maybe swap it for a small tax-exempt model perhaps?
My thinking exactly Jim, although SWMBO is hoping I'll just settle for one car, she is also hoping to shoot a pig down for bacon sandwiches I believe!! :-D
I am thinking about another ZX or maybe a Visa/GS if I can find one but have to move the MX3 first which may be easier said than done. According to 'How many left' mine is one of only 5 taxed for the road and another 22 SORN:
MX3 lifespan
MX3 lifespan
Even when new less than 1000 were imported so obviously not generally popular, which is a shame because having owned mine for 8 years I found it a great little car!! :-D
https://www.carandclassic.com/l/C2093390
https://www.carandclassic.com/make-an-o ... 220-8qya58
https://www.carandclassic.com/car/C2071824
x 8365
mickthemaverick wrote: 17 Jun 2026, 06:49
:lol:
mickthemaverick wrote: 17 Jun 2026, 06:49 I am thinking about another ZX or maybe a Visa/GS if I can find one
A GS with a C-Matic would be a great choice :cool: I know of a nice ZX for sale near Towcester but exceedingly spicily priced and has the wrong gearbox for you :(
x 1067
Unread post by Rp0thejester »
Okay what have I missed?? From what I understand your left leg is naff, so was it Jim's fault riding a bicycle he loaned you? Or have you gone all old man and tripped over nothing?
x 8085
I dislocated my foot falling off a step ladder 10 or so yearrs ago and it was wrenched back into place under general anaesthetic and I have not been able to use a clutch for any length of time since. So autos for me!! :)
x 1067
Well I never knew that!! You kept that quiet.
x 8085
It has been mentioed 16 times according to our search feature, here are a couple of examples:
viewtopic.php?p=683846&hilit=Ankle#p683846
viewtopic.php?p=716961&hilit=Ankle#p716961
And where I told the story:
viewtopic.php?p=660322#p660322
:-D
x 8365
Rp0thejester wrote: 20 Jun 2026, 00:29 Well I never knew that!! You kept that quiet.
mickthemaverick wrote: 20 Jun 2026, 01:11 It has been mentioed 16 times according to our search feature, here are a couple of examples:
Come on Ryan, pay attention and keep up!
