Anyone have access to rneg firmware update? peugeot 3008 2012 executive
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
x 6947
Re: Anyone have access to rneg firmware update? peugeot 3008 2012 executive
Won't be firmware - likely to be the internal GPS tuner, the GPS aerial connection at the back or the GPS Aerial.
To test, connect a cheap GPS aerial from ebay for a tenner with fakra connector, connect to back of Head Unit, put the aerial on the dash and drive for 10 minutes (this will not work if the car is stationary - the vehicle must be moving to get a satellite lock). If after the drive it is still showing no satellites, then this rules out the aerial as the culprit, which means the head unit is likely toast.
Let me know what your current installed firm is and I will check, but I can tell you that none of the firmware updates for this system relate to this issue.
piljkesam
Unread post by piljkesam »
Can i get link for maps europe
alpersagu
New User
Unread post by alpersagu »
I am currently driving a 2011 Peugeot 308 CC and my current firmware is
rneg_D_R28a_R28.01
Is there any new updates for it and where can I download it? Thanks.
x 1944
@alpersagu
Check your PM shortly.
JackoJuaquo
Unread post by JackoJuaquo »
Sorry to hijack the thread, but thought it better than starting a new topic - would anyone have the R50 firmware? I've seen some links elsewhere but no luck. Just swapped out an RT4 for an RNEG in my C5, nearly impossible to find an RNEG2 in Ireland so went with RNEG and I'll source a USB Box or similar eventually. Bluetooth phone audio is absolutely brutal, mic not terrible but return audio from the phone sounds one legged, almost like there a different active signal summing with the audio from the phone. Could just be a broken unit but I thought it was worth to update firmware a try as I seen in some release notes there are audio fixes.
x 1944
Check your PM in a minute or two.
This is not my link and I have no control over it. Usual precautions, use at own risk, etc. Please post back here with your result.
From looking around this seems to be the fixes in this final release.
Bugs fixed:
• Restarting: beginning of a random calculations in breadcrumb;
• Several bugs in Bluetooth (incompatibility with some phones, Bluetooth pairing loss at the beginning of a phone call, poor sound quality);
• The "unknown" message appears instead of the name of the caller when a call is received;
• Incorrect calculation of radar speed for vehicles with unit speed in miles;
• Navigation restarts to activate the "Demo Mode" navigation;
• Navigation mode: ?ursor frozen. Cursor is placed not to the actual vehicle position;
• Estimated time of arrival is incorrect. Estimated time of arrival is underestimated during guidance;
• Random loss of audio settings after starting the engine;
• Sound is lost after starting engine;
• Random sounds after starting the vehicle;
• Yellowing of multifunction display;
• Random loss of date, time and altitude;
• Call History is not visible in the multifunction display."
JackoJuaquo
Thank you- quick enough process actually. The overall audio of my system is much improved. I’ve the Philips hifi system and the tweeters are really difficult to drive, seems to have given a bit better treble. Otherwise nothing to report, I’ll eventually get around to uploading maps and I’ll try the nav and report back. As for Bluetooth- definitely a marked improvement, however audio is now muffled. Very odd but perhaps just a bad Bluetooth circuit. Thanks for the firmware!
misa1411
Unread post by misa1411 »
Hello, currently i am driving Citroen C5 with software rneg_D_r29a_r29.01, can i update it to new version, also I want new maps
x 1944
Check your PM for a link to R50. It's not my link and I have no control over it. Usual precautions, use at own risk, etc. Please post back here with your result.
I have seen links for updates to maps originally provided for VW and BMW vehicles but I have no knowledge of how successful they are and certainly couldn't provide any help if things go wrong.
misa1411
Thank you for fast replay, what I get with software update?
x 1944
See my post 4 above this one.
viewtopic.php?p=858618#p858618
x 1944
misa1411 wrote: 02 Apr 2026, 10:27... also I want new maps
Check your PM. I have sent you some information about this. It's not my information, I am only passing it on. Please let us know how you get on.
x 1944
@misa1411
You haven't checked your PM yet.
Jcbmbranco
New User
Unread post by Jcbmbranco »
I’d like to update the firmware and maps to my Peugeot 3008
Can someone help me with the files
Tigerclaw26
Unread post by Tigerclaw26 »
Any chance you can send me the update for my 2012 hybrid4
Steven
