Anyone have access to rneg firmware update? peugeot 3008 2012 executive
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
Peugeot20123008
Unread post by Peugeot20123008 »
I have purchased a peugeot 3008 2012 executive. My system says I have rneg_D_R29a_R29.01
I saw the sticky on this sub forum regarding updating, however I don't have a copy on of the lastest firmware avaliable to use for my system. Would anyone be able to help me out? @GiveMeABreak
I believe if I update the firmware I get better view of maps?
Thanks in advance,
x 6948
Re: Anyone have access to rneg firmware update? peugeot 3008 2012 executive
I’ll send you a PM with links later
Peugeot20123008
GiveMeABreak wrote: 02 Nov 2020, 20:04 I’ll send you a PM with links later
Thanks a lot 8-)
Gypas29
New User
Unread post by Gypas29 »
Hello,
I also have a Peugeot 3008 eHDI 2012 and I wanted to ask if this update is about the car stereo functions or the maps. In any case, I would appreciate it very much if I could have the links for the firmware update.
x 6948
@Gypas29: Pop your VIN up so I can check your system first, as I suspect you don't have the MyWay system.
Peugeot20123008
Hi Marc,
All updated. I did each install in order and all seemed to go ok. Took just under 30 mins for each install.
I can't seem to notice any difference with the nav. Maybe I was mistaken, but I thought that the viewing angle of the maps was changed in the latest update? I can still only view from birds eye view.
x 6948
That is changed in the NAV settings as to the type of view you want. To access these settings, you first need to setup a navigation journey.
Then press the dial and select Map Settings and choose the orientation from there.
ntinakos90
Unread post by ntinakos90 »
Hi Marc,
Is there any chance that you can send any link in order to update my RNEG Firmware version. I have got the R20 at the moment. I have just upgrade my car from RD4 to RNEG.
Regards
Konstantinos
x 6948
I’ll get you a link in the morning
ntinakos90
Thanks Marc
Regards
Konstantinos
x 6948
I've sent you a PM Konstantinos
Steveo
x 13
Sticky
Unread post by Steveo »
Hi Marc
Is there any chance of a sticky with the links or is it pm only
Thank you
Regards
Steve
x 6948
Hi Steve, I only supply the links via PM and don't keep them live all the time. So PM me if you need any updates.
Steveo
x 13
Cheers Marc
Mine is on 40 03 if that makes any sense?
What's the latest because it my help my Bluetooth (occasionally drops out), since downloading covid app
Regards
Steve
x 6948
Yes, there is a later version than that. I'll send you a PM
