P11AC has anybody got any ideas. Eml on and red message to stop wait 5 mins then off we go as long as we keep it under 50mph.
Ds5 diesel hybrid 4 fuel issue
Leejasp
Re: Ds5 diesel hybrid 4 fuel issue
Car started drives fine until going up hill or over 50mph. When checking error codes it has thrown up the following.
- x 6955
Here you go:
| Fault Code: | P11AC |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
rkomzz
Hello,
I have the same problem, did u solve it?
Leejasp
Fuel filter housing had tiny crack letting air in. I had injectors done fuel pump fuel filter etc.. byt it was housing.
Lee
Lee
