Coincidentally, perhaps Neil has the solution:-
viewtopic.php?p=864950#p864950
I'm sure that I have some square bits here. A quick and dirty search brings them up from several sources including Farnell:-
https://uk.farnell.com/wiha/7013-z-3-0m ... dp/1566736
C5 X7 aux belt tensioner.
- x 5674
wurlycorner
- x 271
Re: C5 X7 aux belt tensioner.
Different engine, but for reference Peter; on the suggestion of alternator over-run pulley being the cause - I did a video of what the symptoms looked like on my X7 (different engine, but definitely the alternator pulley that was the cause).
In this post here viewtopic.php?p=837574#p837574
Iain
CX DTR T2 Safari (silver)
Iain
- x 1240
Its a brand new tensioner Mick, and it certainly isn't weak. I think I will try changing the alternator first - its much easier!.
Lenny
- x 63
This is a better video..
...includes how to check the alternator clutch pulley.
It'd be a bit overkill to change the full alternator of it's just the pulley that's worn out.
Gates (the belt manufacturer) say the pulley and aux belt should be changed together. Both are a pretty normal service item.
wurlycorner
- x 271
If you can get them... NLA for the 3.0 HDi alternator when I looked - not to mention impossible to access while on the car! (But that's 3.0 HDi specific woes for us idiots that own them and not relevant to this thread...)Lenny wrote: 01 Apr 2026, 21:18 Gates (the belt manufacturer) say the pulley and aux belt should be changed together. Both are a pretty normal service item.
Iain
Iain
