I'm so glad I am not a lone hoarder...MattBLancs wrote: 23 Feb 2026, 21:00 I've also got a set of these:
Link from eBay:
https://ebay.us/m/vwWYOX
Which are also very useful - designed to be hit but also a hex to allow them to be turned with a spanner.
Not too aware of garage sales in the UK - we tend to have "Car Boot Sales" where folks assemble with their, miscellaneous tat / second hand treasureat central location, commonly car park if a sports ground or similar.
I do t know a great deal about car boot sales as I've near deliberately stayed well away from them - my hoarding tendencies would end up with me accumulating loads of useful stuff I'm sure!
Some puzzles for me and my 307
Rhothgar
- (Donor 2026)
- x 221
Re: Some puzzles for me and my 307
Rhothgar
- (Donor 2026)
- x 221
But doesn't hammering a magnet make it loose its properties? They look like a really good set for the price especially. The hex might be useful but you would need the exact size of head on the screw to avoid damage as I am sure you will know.MattBLancs wrote: 24 Feb 2026, 05:45 Good thoughts folks! I have got a magnetiser/demagnetiser block thing, but like the electromagnetic idea too.
I believe the key property of the screwdrivers discussed above is around that pelting the end of them with a hammer is designed in to their construction (and hence isn't an act of tool abuse!) hence the "hammer - through" or (yuk!) hammer-thu term used.
Very good though for using as a makeshift impact driver. Much better in fact as you can hold the screwdriver with your hand (elbow at 90 degrees to form a lever). Apply judicious torque whilst hammering the head. More control than an impact driver in my experience.
Rhothgar
- (Donor 2026)
- x 221
Sorry but I've no idea on a 307. Mine is on a Xantia.ozfrog wrote: 10 Mar 2026, 20:07Where, please?Rhothgar wrote: 16 Feb 2026, 12:55
P1403 and P1404 relate to the addition water heating block on the bulkhead below the windscreen.
If you need if I can find the link to one of my recent posts about repairing mine. I had the codes for 3.5 years and only just got around to it in December 2025.
Basically, the first thing to check is the nut to the earth wire which should be a thick white wire connected to the back of the block. See if you can undo it with your fingers. If not, undo it, clean up mating faces and replace nut. A bit of Thread-lock wouldn't go amiss and don't go Neanderthal on tightening the nut as the stud is a small shank.
Next. If fault still exists, remove the rubber covers and carefully remove glow-plugs. Clean up all surfaces. Test for continuity between threads and shank where nut screws onto. Replace any that are out of range. If you are the careful type, you can test the glow-plugs across the battery but holding with a pair of pliers, applying to battery positive and a thick earth wire to the threads. I use 2.5mm 240V mains cable. The tip should glow red. DO NOT TOUCH! and put them somewhere sensible to cool down for a while afterwards. Even when they are not red they are still damned hot. You will only touch them once...
Find your heater matrix and look back along the pipes which will run along the rear bulkhead and if you have the same type of aluminium heater block it will be plumbed in quite close to the heater matrix. I'll take a photo of mine so you can see what you might be looking for assuming yours is the same type. Unless the 307 had an Eberspracher type heater below the wheelarch?
- x 2336
I think that's true. I'd not worry too much about the magnetic properties, these are more about the "pounding it into submission!" capabilities!
Err, "depends on application" ! Sometimes I have gone up a size (e.g use PZ3 in place of PZ2) if the screw has been pre-mangled for me by others.They look like a really good set for the price especially. The hex might be useful but you would need the exact size of head on the screw to avoid damage as I am sure you will know.
Yes, exactly this, the ability to be "mostly impact, little bit of torque" (or I guess, visa versa) is a really good benefit to using these.Very good though for using as a makeshift impact driver. Much better in fact as you can hold the screwdriver with your hand (elbow at 90 degrees to form a lever). Apply judicious torque whilst hammering the head. More control than an impact driver in my experience.![]()
Manual impact screwdriver (i.e. hit with hammer type) also I think is better success rate than electric (mostly on the basis the former is impact plus twist, the latter is just a torsion hammer effect)
- x 2336
- x 1938
Yes to a certain extent depending on how naturally magnetic it is.
I remember an experiment at school which showed the opposite effect. Bashing an iron or steel rod would leave it weakly magnetic. ISTR it was an effect best seen if the metal rod was in a north south orientation as as it was hit.
- x 2336
By eck, I'm not turning the car round to get my screwdriver polar aligned!Paul-R wrote: 23 Mar 2026, 12:52 Bashing an iron or steel rod would leave it weakly magnetic. ISTR it was an effect best seen if the metal rod was in a north south orientation as as it was hit.
ozfrog
- (Donor 2026)
- x 76
MattBLancs wrote: 23 Mar 2026, 13:47 By eck, I'm not turning the car round to get my screwdriver polar aligned!![]()
Matt, you're worried about turning the car around? I'm worried that Paul can remember something from (high?) school!
Cheers,
Andrew
Andrew
Rhothgar
- (Donor 2026)
- x 221
Sorry for late reply. Thought I’d taken more if a zoomed out photo too but clearly not. The glow plugs are under the four rubber caps.ozfrog wrote: 10 Mar 2026, 20:07Where, please?Rhothgar wrote: 16 Feb 2026, 12:55
ozfrog
- (Donor 2026)
- x 76
Apologies, all. Things here have not been good for me for a while.
I think I might be able to get to see under the bonnet of my 307 on Friday - as long as it doesn't rain!
Cheers,
Andrew
Andrew
ozfrog
- (Donor 2026)
- x 76
Very nice of you to offer. Thank you so much.MattBLancs wrote: 23 Mar 2026, 06:42Stick a picture of your meter up on here, I'm sure we can talk you through it (easiest if we can see what you've got to play with)ozfrog wrote: 23 Mar 2026, 03:47Yes, but not completely competent with it. And even more lacking in confidence with it.If you have a multimeter
This is it
https://autobarn.com.au/ab/Autobarn-Cat ... oductIndex
Cheers,
Andrew
Andrew
Onlinemyglaren
- x 5670
That link looks broken, or something
Rhothgar
- (Donor 2026)
- x 221
They've just got a block on IP's from the UK. So you just have to pretend you are in Australia, Steve...
Here it is.
Here it is.
Onlinemyglaren
- x 5670
Didn't think of using the VPN for that.
- x 8083
Although that works I think it's better to encourage attaching pictures directly to ensure valid posts in the future.
Follow this guide:
viewtopic.php?p=516529#p516529
Follow this guide:
