RT6 firmware
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
devlinr
RT6 firmware
Unread post by devlinr »
Hi,
I have a Citroen C5 Tourer with an RT6 or eMyWay system, its flash memory the MicoSD card in the unit has failed (totally unrecoverable) and I am replacing the SD it but need the RT6 firmware download to re flash it with instructions please.
Reason: Moved to RT6 Forum
x 6945
Re: RT6 firmware
Replacement of MicroSD Card Instructions:
viewtopic.php?t=63227
Upgrade Instructions:
viewtopic.php?t=75448
Firmware V2.86, check your Private Messages.
novawaves
Re: RT6 firmware
Unread post by novawaves »
Hi
where to find the latest firmware?
x 1938
Re: RT6 firmware
What version do you currently have fitted? Why do you want to update?
I have 2.77, 2.80, 2.85 and 2.86 as an ISO to burn a CD. I also have 2.86 to put on a USB stick.
GiniDini
Re: RT6 firmware
Unread post by GiniDini »
Paul-R wrote: 06 May 2025, 09:36 What version do you currently have fitted? Why do you want to update?
Hi im searching for the 2.85 Version du Update my currently FW 2.21. Ive read that Updating from lower Version directly to 2.86 can cause Problems.
Best Regards
Dom
x 1938
Re: RT6 firmware
According to the attached charts updating from 2.21 to any later version will mean losing your configuration settings. This will need either paying a dealer so that they can download the configuration files from the Stellantis servers or using Diagbox to change individual settings. You should be able to use Mirascripts to download the configuration file before you update and then apply it after updating. I strongly suggest that you do this.
Check your PM for a link in five minutes.
Dragan-DS4
Re: RT6 firmware
Unread post by Dragan-DS4 »
Uh, how many users with the echo problems after the update to 2.86... :-D
I tried to solve the problem with both Diagbox and MIrascript and it doesn't work at all, does anyone have a solution?
I need to go back to one of the previous versions eg 2.85 and test it.
Someone to help me? Any download link for 2.85, or maybe some another versions to try? :-k
x 1938
Re: RT6 firmware
If you've installed 2.86 then there's no going back to an earlier version.
If you can't get Mirascripts to sort the echo out then you can pay a dealer to download the configuration file for your car from the Stellantis servers in France.
Dragan-DS4
Re: RT6 firmware
I am willing to try and i think there is a way to forced install.
Can you send me version 2.85 (if possible version 2.85b :) ) and 2.80.
If I succeed, I will report the solution, it will be of interest to many users \:D/
dexsternn
Re: RT6 firmware
Unread post by dexsternn »
Dragan-DS4 wrote: 24 Feb 2026, 21:59 I am willing to try and i think there is a way to forced install.
Hi! did you roll back the firmware?
Dragan-DS4
Re: RT6 firmware
dexsternn wrote: 13 Mar 2026, 10:48
Unfortunately no, it doesn't seem possible to do without a big risk of permanently damaging the device itself. I was not ready for such a risk.
Better not to use phone while driving than to drive in silence without music :-D .
We are waiting for a new update with the hope that it will work better than the current one.
Brandon1998
Re: RT6 firmware
Unread post by Brandon1998 »
Hi,
I have Citroën C4 II 2012 with RNEG2.1.G.5
I want to update from 2.1 to 2.80.
Is it recomanded to upgrade from 2.21 before 2.80 ?
Where can I found thefirmware files please ?
Thanks.
x 1938
Re: RT6 firmware
Why do you want to upgrade to 2.80? What problem do have using 2.1?
Brandon1998
Re: RT6 firmware
Paul-R wrote: 04 Apr 2026, 22:08 Why do you want to upgrade to 2.80? What problem do have using 2.1?
Hi Paul,
Thanks for your answer.
My bluetooth disconnected permanently : when I listen music mostly. When I'm calling, I have less problems.
x 1938
Re: RT6 firmware
If you look at the tables ten posts above this you can see that updating from 2.1 (actually 2.10) is only advised to 2.21 to be good. Any higher version will need a Diagbox session which means going to a Citroen dealer so they can connect to the servers in Paris to download the configuration file for your vehicle. They will charge for this service.
You should be able to use the Mirascripts program to download the current configuration from your vehicle before you go to the higher updates and then upload this configuration to new firmware. This should work although a post above says that they had failure doing this. Mirascripts can also change your configuration (for volume, Bluetooth echo, etc) although I have never done this.
Check your PM for a link to download 2.21. This is a version to load onto a USB stick. Usual disclaimers, use this at your own risk, etc.
Use Mirascripts to download your configuration first just in case of an unforeseen problem. Let us know if this works for you and then, if necessary, I can provide links to later firmware versions.
