Lexia enable ECU TMPS
Spix
Unread post by Spix »
Hello i need an help.
I have lexia and 9.186 program version.
Several months ago, I disabled the Tire Pressure Monitoring System (TPMS) ECU module because one of my sensors was faulty.
I have now fixed/replaced the sensors and am attempting to re-enable the module and perform the sensor acquisition/learning procedure, but I am encountering an issue.
I am unable to successfully enable the sensors. I'm attaching a few screenshots of the process (which I can't include here, but they show the steps).
The strange thing is that when I try to start the acquisition, the procedure first instructs me to switch the ignition OFF. Then, it asks me to start the engine. As soon as I start the engine, the connection seems to be immediately reset/lost.
Could you please help me? Am I performing the procedure incorrectly, or would it be better to try downloading an older version of the software?
x 1056
Re: Lexia enable ECU TMPS
Unread post by wheeler »
Have you actually re enabled it?
You may need an 'exciter' to wake the sensors up.
Kees
x 147
Unread post by Kees »
Just enter the oke key without switching of the engine and also when it says, start again.
Spix
When i start again ask me to put key in ignition off.
I have look a video on YouTube and during diagnosis general at the end ECU module is deflation tyre, I don't have more this.
Where is menu for enable ECU module?
Spix
I have checked with old screenshots, and i confirm that learn procedure for tmps working.
Why is there a reset of communication
Spix
Can anyone check if id tyre sensor are numbers or only 0
Spix
Update:
Add id sensors and now it's work.
In fact at the begin i have a real low pressure, after i have no alarm.
But the procedure for learning sensors go in error for engine power on. Any advice?
Other question, is there a system for look pressure of tyres on car display?
Spix
Is there a way to display real-time tire pressure on the dashboard, or does the control unit only send a notification when a tire is flat?
Spix
About the option inside autodiag, filter for deflation detection, what's the difference between normal and selective filtering ?
Spix
Image attached
wurlycorner
x 271
Unread post by wurlycorner »
Spix wrote: 09 Jan 2026, 19:39 Is there a way to display real-time tire pressure on the dashboard, or does the control unit only send a notification when a tire is flat?
I believe it only provides warnings, not live display of pressure (frustrating considering the ECU does have that data - the X7 is the same).
Sorry not able to help on the other queries.
Iain
CX DTR T2 Safari (silver)
Spix
Thank you, very much!
Spix
wurlycorner wrote: 21 Feb 2026, 13:27
Thank you very much!
