Engine oil relay 2.0 bluehdi DW10FU
x 1056
Re: Engine oil relay 2.0 bluehdi DW10FU
Unread post by wheeler »
This is the oil spec for your van
Removed at request of OP
Edited version re uploaded
x 1941
And to confirm that oil of 5W/30 to FPW9.55535/03 specification is correct.
tricoloured
x 14
Unread post by tricoloured »
Hi
According to TDS info from the Mannol site the 7703 Energy Formula isn't FPW9.55535/03 specification, I have looked at it before.
Please correct me if this is not the case.
This is from the Mannol 7703 TDS:
Specifications
SAE 5W-30
ACEA C3
Recommendation
API SN Plus
API SP
ACEA C2
PSA B71 2290
PSA B71 2297
FIAT 9.55535-S1
FIAT 9.55535-S3
Regards
x 1941
Link to the Mannol PDF for the 7703 oil https://www.mannol.de/create-pdf/317/en
I think an email to Mannol technical department is needed. Maybe FIAT 9.55535-S1 or FIAT 9.55535-S3 is equivalent (Fiat is owned by Stellantis) to FPW9.55535/03? Although I suspect they're equivalent to B71 2290 and PSA B71 2297.
x 1941
Hmm, further investigation of the Mannol web site seems to indicate that 05000ST Motor Oil 5W-30 Premium Synthetic ST is now the correct oil for FPW9.55535/03 use.
https://www.mpmoil.uk/blog/change-in-re ... s-vehicles and https://cdn.mpmoil.com/mpmoil-assets/7b ... 324210.pdf
x 1056
Paul-R wrote: 14 Feb 2026, 20:16 And to confirm that oil of 5W/30 to FPW9.55535/03 specification is correct.
Re uploaded edited version, yes that is one of the approved oils.
Mark 1972
Unread post by Mark 1972 »
Yep the mannol oil is badged up correctly.
Hope our discussions help others and thanks all for the help during this
perfidus
x 6
Unread post by perfidus »
Very interesting topic for those not using a Stellantis dealer workshop for changing oil.
I found myself in this situation with a DW10FUC BlueHDi 2.0L engine with about 150K Km.
On my last oil change the garage told me I should use 5W30 not 0W30 ACEA C1/C2 like in the service manual I have, because PSA has changed oil specifications from 2016.
So I bought Total Quartz INEO ECS with 5W30 viscosity but with PSA B71 2290 specs (they probably only heard something from the dealer but not all).
I see now that spec B71 2290 oil IS NOT RECOMMENDED anymore so I must be using the wrong oil.
Now it's due for a new change of oil and this helps me a lot! Thank you for the info!
Those who don't know history are destined to repeat it!
