Hello.....my name is Betsy
x 2006
Unread post by Stickyfinger »
My name is Betsy and I am a dirty girl..........I have been locked in a sparrow infested drafty garage for 6+ years until liberated the other day....
I can slide on Old Speckled Hen cans :)
(What happens when a total pratt forgets to bring my keys and the steering lock is on !!!)
and yes, my lower front wings are a bit frilly....clean out the leaves and muck folks !
x 8153
Re: Hello.....my name is Betsy
Nice colour, which motor has it got Alasdair? :)
ekjdm14
x 269
Unread post by ekjdm14 »
Heavens to Betsy that's mucky!
I'll get me coat....
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
x 2006
mickthemaverick wrote: 04 Feb 2026, 20:04 Nice colour, which motor has it got Alasdair? :)
1ltr, 4-speed = POWWWER !
Same as my white 3-door..... I had hopes that it would be Blue, sadly the Red White Blue line-up will have to wait. (never had a blue car in my life)
x 2006
I think I have found the reason there is no fuel getting to Betsy's throttle body/injector....
E10 Rubber rot and rust .....in tank pump is more rotten than Starmer's judgement calls
x 8436
It's great you've rescued Betsie Alasdair :D Under there you may well find a lovely little diamond :cool:
My long-range diagnosis of a failed fuel pump was pretty much spot-on then ;)
That's certainly suffered badly and if all down to E10 petrol, somewhat worrying. I'd be tempted to check your other AX and the Saxo you are involved with as they use a similar pump.
x 8153
A grim looking result of using E10 petrol indeed! Further evidence confirming why I run both my old cars exclusively on Shell Vpower E5 !! :)
ekjdm14
x 269
Stickyfinger wrote: 05 Feb 2026, 19:42 I think I have found the reason there is no fuel getting to Betsy's throttle body/injector....
I think the ethanol thing is more of an issue on cars that sit more than a year, rust-wise at least (probably still makes rubber turn to concrete no matter how fresh).
I do have to strongly disagree on the Starmer thing though, the pump looks positively beautiful in comparison to the any decisions coming out of that excuse of a person.
x 8436
ekjdm14 wrote: 06 Feb 2026, 17:24 I think the ethanol thing is more of an issue on cars that sit more than a year, rust-wise at least (probably still makes rubber turn to concrete no matter how fresh).
That's why I'm keen to see a similar pump that's in regular use. Daffodil's may give us an answer to this Alasdair ;)
I can't help here as both mine have carburettors so no in-tank pumps...
x 2006
That may have to wait, every bit of "its not raining" time I get I need to concentrate on getting Daffodils lower arms changed and her interior Desoggyfied
x 5678
Stickyfinger wrote: 07 Feb 2026, 07:26 That may have to wait, every bit of "its not raining" time I get I need to concentrate on getting Daffodils lower arms changed and her interior Desoggyfied
Would a dehumidifier be of any use?
x 2006
No...the 1000rpm spin cycle and a radiator sorted stage 1 :)
To fully desoggyfie one needs to chase down and plug the source
x 2006
Fuel pump rebuilt........
x 2006
Will she won't she ???
x 8153
That sounds sweet Alasdair, well done, now the next question is: Does she drive? :-D
