Yes, and it is alleged what became the 205 was found on the Simca drawing board when PSA took them over...
- x 8422
Huskyxantia
- x 925
Never knew that, that would of been an interesting development if it had happened, as regards my samba i remember a couple of things about the car when I had it , it used to lean quite a bit if you cornered hard & being a wally (I was only 20) I remember putting my foot down through a village that had a mean hump back bridge its was about 12 midnight I got it up over 30 (wow) and hit the hump of the bridge ... it took offCitroJim wrote: 03 Feb 2026, 06:28 Ahh, the good old SambaFun fact: the AX was originally to be the new-model Talbot Samba - before PSA killed the Talbot name...
Husky.
- x 8422
Yep, once you reach a certain age you fully appreciate that
- x 2362
At the Peugeot dealer presently (waiting for them to open at 8:00) as the blue 308 is having it's recall.
As it's a "Stellantis &You" I'm surrounded by Fiats and Vauxhalls a plenty!
- x 2362
More detailed "review" coming later but here was my transport for some of today, an electric... Well I'd assumed 3008 as it's quite big! Ha ha nope this is an e-2008 it seems!
308 recall completed and they gave me a nice video and list of jobs "needing" doing, a "review" of those to follow....
- x 2362
Err, ok? Found some additional details. Slightly odd "they are effective, but might need replacing". Suppose that's true. Think I will monitor them as suggestedwiper system £0.00Rear Wiper Blade is Working Effectively - May Need Replacing Before Your Next Service. Please Monitor.
Front Wiper Blades are Working Effectively - May Need Replacing Before Your Next Service. Please Monitor.
Translation: new number plate lights. (As per additional detail, also quoted)lights at rear of the vehicle £37.56Nearside Number Plate Light Bulb - Needs Replacing and Testing. 0.1 Offside Number Plate Light Bulb - Needs Replacing and Testing. 0.1
Reality: they are LED (and working. Not spot lighting the floor like some aftermarket LEDs! I'd say close in output to the filament bulb originals)
Over the phone I thought this was flush and replace but their sheet suggests just top up to level.Coolant\Antifreeze Level : £94.99Vehicle Antifreeze Protection Level - between -15°C and -23°C - Antifreeze Change Advised Soon - It is also starting to become less effective at providing overheating protection or engine anti-corrosion protection, 0.5 Antifreeze\Coolant ½ Full - Top Up Advised Soon.
Reality: coolant sat on the max line, where it should be.
(I think a flush would be justified, as it's not the rich red colour it out to be (another flush is on the cards, when the weather is fit!))
Additional detail added: I think -15 to -23°C is fine!
Reality: it was half way between max and mine lines. I took bottle of oil with me and put perhaps half a litre in.Engine Oil Level : £16.55Engine Oil - ¼ FULL 0.75 Litres Short.- Top Up Required - Low oil level will lead to increased friction within the engine causing excess wear, increased emissions and reduced fuel efficiency. It also significantly reduces the life of your engine components
Additional detail: ah, they agree it's a bit low. A bit.
Accepted (as in agree needs doing!) on both counts. Wow, nearly £700 though!Front Brake Pads and Discs : £379.00
Rear Brake Pads and Discs/Hubs : £299.00Front Brake Pads 80% worn - That's 2mm of material left until you reach the manufacturers minimum thickness. (A) Front Brake Discs 80% worn - That's only 0.4mm until you Reach the Manufacturers Maximum Wear Limit. (A)We Recommend Changing the Brake Discs with the Pads Rear Brake Pads 70% worn -That's 3mm of material left until you reach the manufacturers minimum thickness. (A) Discs corroded.
Ok, so they've the equipment to measure the disk thickness and think front disks are on the thin side. I will seek out a pair of disks for the front too.
Video description states slight play in ball joint (driver's side) both wishbones (and associated bottom ball joints) are less than 2 years old I think. Quite disappointed if giving up already!Front Suspension excluding Shocks and Springs : £224.90Offside Front Ball Joint - Needs Replacing. Ball joint worn.
This is a good spot, I think this is source of mystery noise I've had in last week. Not noticed before that (and not mentioned by MOT man either)Exhaust System and Catalyst : £215.03Exhaust Rear Silencer - Flexible Mountings Required
Research on the parts ongoing, looks to be between £5-£35 for the mounts themselves.
Haha, that's a price I can't quibble with!General Comments and Observations : £0.00
Additional detail:
Also mentioned/shown on the video was that the front passenger side arch liner is cracked. Yes, it definitely is!Observations
Observations Noted: NSF wheel arch liner broken.
It's one I've fixed with the hot staples in the past, but the whole thing is brittle so it's time to change the whole thing.
Quite surprised they've not priced me up one if those given it's clearly had it!
- x 2362
3rd August 2024 those wishbones went on!MattBLancs wrote: 06 Feb 2026, 17:13Video description states slight play in ball joint (driver's side) both wishbones (and associated bottom ball joints) are less than 2 years old I think. Quite disappointed if giving up already!Front Suspension excluding Shocks and Springs : £224.90Offside Front Ball Joint - Needs Replacing. Ball joint worn.
viewtopic.php?p=808306&hilit=Wishbone#p808306
FAI brand. Not impressed!
- x 2362
Wheel arch liner:
DIEDERICHS Wheel arch liner - AUTODOC
https://m.autodoc.co.uk/hd-karosserieteile/13881728
£30.99
Shame this one is out of stock!
Hey, check out PRASCO Wheel arch liner in the AUTODOC app https://m.autodoc.co.uk/prasco/14466068
= £17.49!
eBay £32.99
https://ebay.us/m/19z1re
Exhaust mount:
Front one: Holder, exhaust system - AUTODOC https://m.autodoc.co.uk/fa1/21931708
£10.99
Rear one, proving more elusive!! Edit, found it, eBay:
https://ebay.us/m/zORzkJ
£9.88
£30.99
= £17.49!
eBay £32.99
Exhaust mount:
£10.99
£9.88
- x 2362
Enterprising chap attempting to fix his 308 mount:
And, after it failed a part 2
I think for sub-£10 I'll just get one ordered. Will likely have a play at sticking the old one (and keep as a spare)
- x 2362
Wonky ball joint: I've emailed the eBay seller. I have in mind the wishbones were supposed to be 2 year warranty (but cannot find details to confirm that now) so will see what reply I get. They've other brands of same component for sale now, listed with 2 year warranty.
Autodoc has Febi brand ball joint for £12.99
https://m.autodoc.co.uk/febi-bilstein/16180609
So no great issue if eBay seller tells me to get lost
- x 2362
Peugeot dealer price to beat, round 1:
£9.88+£9.66= £19.54 (91% saving)
EDIT
First one = incorrect!
Hence: £12.85
£9.88+£9.66+£12.85= £32.39 (85% saving)
2 down:Exhaust System and Catalyst : £215.03
EDIT
Hence: £12.85
Huskyxantia
- x 925
Very detailed there Matt, ive every faith in you your get these all done , weather forecast my end 7 to ten days of wet stuff lol but we all know that can change, with the wind direction
Husky.
- x 8422
That's a very comprehensive list Matt... Looks like a very overt attempt to drain your bank account...
Just supposing you were an average member of the public and knew no better...
- x 2362
Ha ha, yes I've copied it out and then there's a fair bit of "thinking aloud" on my part.Huskyxantia wrote: 06 Feb 2026, 22:15 Very detailed there Matt, ive every faith in you your get these all done , weather forecast my end 7 to ten days of wet stuff lol but we all know that can change, with the wind direction
Most jobs can wait for a break in the weather, even the front pads that's the most pressing have a few months life before we're metal to metal.
Absolutely, not quite there with this one (in terms of how much it's worth), but I'd think there's cars get scrapped when their low value is contrasted against a scary huge list like that!CitroJim wrote: 07 Feb 2026, 05:05 That's a very comprehensive list Matt... Looks like a very overt attempt to drain your bank account...
I will tot up my actual costs for fixing all the above in due course. I'm certain I can be well under a half the cost, see if I can keep below a quarter????
- x 8145
All part of the scheme to get people to scrap old cars and buy new electric ones so the electricity companies can fleece us instead of the oil companies!!
