C5 X7 2009 Petrol saloon Hydraulic Leak rear ew10a
woolybully
x 4
Unread post by woolybully »
Hi
Have substantial fluid leak just above fuel tank towards the offside rear.
Can anyone tell me which pipe is most likely the culprit ??
Tony
wooly
x 8151
Re: C5 X7 2009 Petrol saloon Hydraulic Leak rear ew10a
Hi Tony
You cannot attach videos directly but if you upload it on Youtube and then post the link they give you we will be able to see it. :)
woolybully
x 4
Ok thanks
wooly
aerodynamica
x 215
Unread post by aerodynamica »
Oh, I think it's the long front - to -rear pipe that has a rusted bit. Mine did the same and it's not the easiest thing to replace. It goes up and over the fuel tank. Some people cut the pipe and add a repair section but I don't recommend it. I am not sure how available the pipe is. I ended up getting an aftermarket copper pipe with special ends from a guy who made them in Russia. That's not really an option any more for obvious reasons.
Graeme M
aerodynamica
x 215
You might be able to get a special pipe from this supplier in Poland. This was from another thread lately.
AJ_Artur wrote: 15 Jan 2026, 12:44 Hi,
If anyone needs to repair or replace this in a similar way but doesn't have access to tools or the necessary skills, I recommend these solutions:
https://piterparts.online/redukcja-prze ... p-722.html
Graeme M
woolybully
x 4
Have hopefully fixed the leak .....
It was a pin hole in the pipe where it clipped to underside just above fuel tank.
Managed to drop the tank and then access was easy. Got a guy from our local Pirtek hydraulic specialist to come out he cut the pipe, flare the ends and connect them with a suitable connector.
Replaced the tank and tested it no leaks and suspension now all working again...
Now got to put the rest of the car back together ...
Been a long saga but hopefully soon I'll be back on the road.
wooly
