Hello guys, thanks for your brief explanations.
But I have issue that I couldn't find here.
I have Peugeot 807 (2010) RT6 radio, have common issue with showing Peugeot logo and restarting all the time again and again.
I opened my RT6 unit, but on location right next to the cooler I couldn't find internal Micro SD card, simply it doesn't exists.
Is it possible that some units have only frontal Micro SD slot? Is it possible to do firmware update with that slot?
Or if you have any other suggestion for me what to do, I would be very thankful!
NG4 (not RT6) in 2010 807
- x 1938
Re: How to Replace the Internal MicroSD Card - RT6
The front slot type radios are a different type (MyWay/WipNav/RNEG) from a different manufacturer (Harman Becker). They use different firmware.
Can you take a photograph?
markokacar
There it is.
Harman Becker it seems to be.
- x 1938
Yes it is. Is there an SD card in the front slot? I can't see from the photograph.
You need to look in this section of the forum viewforum.php?f=49
markokacar
There is SD slot. At the photo there is no physical SD card, but I have it, on it it's GPS maps from 2010.
I will check that section of forum. Thanks.
Rhothgar
- (Donor 2026)
- x 221
Seems I am a bit late to the party.markokacar wrote: 02 Feb 2026, 11:02 Hello guys, thanks for your brief explanations.
Paul-r is the new resident genius on these units.
Did you not follow the detailed strip down guide? The micro-SD slot MUST be there.
To my mind, an RT6 is an RT6 is and RT6.
I could be wrong but I'd doubt there were other versions with the same number but I'll happily stand to be corrected. That's how we learn!
EDIT: Just seen your photo.
That is an SD slot not a micro-SD slot. Look inside!
- x 1938
No need to look inside. That is not an RT6, it's a MyWay/WipNav/RNEG head unit.
markokacar
Clearly there is no internal Micro SD card.
Paul, can you send me link in PM for softvare update that I need to do? Should I do it with CD?
Rhothgar
- (Donor 2026)
- x 221
Could an admin please move the posts from markokacar to the relevant sub-thread please to avoid confusion?
- x 1938
Re: NG4 (not RT6) in 2010 807
Done.
