original part number clutch
Autoholm
Unread post by Autoholm »
I would be very happy if someone would give me the original part number for clutch and starter for Berlingo 1.6 16 v gasoline 2006
VF7**************[VIN obfuscated, can be read by forum staff].
Clutch is too hard and plastic clip on pedal keeps breaking. Cable is new and clutch is only 2 years old. It is a Mecarm MK9613 that i fitted 2 years ago. I think it should bo ok. But i would like at Valeo or what ever is the best.
Really annoying to loose clutch so many times in city traffic. Hope i can fix this problem.
Best regards
peter
x 8165
Re: original part number clutch
These are the Clutch and Starter files from your VIS but there could be a number of starter motor options as in the list below. You need to pick one and I may be able to find more about it. :)
Berlingo clutch.pdf
Copied from Servicebox backup
(207.82 KiB) Downloaded 69 times
Example of starter motor file:
Berlingo starter.pdf
(144.93 KiB) Downloaded 68 times
Copied from Servicebox backup - possinle starter motors
