C5X7 double problems today
aerodynamica
- x 215
- x 1939
Re: C5X7 double problems today
Done.
KennyW
- x 165
Graeme,
The rear suspension has tracking adjustments. had same problem on my C5. Changed them took the car back to garage.They made the adjustments and problem solved.
I'll see if I can find a photo of the part.
Kenny
Item no 8
Kenny
Item no 8
C3 1.4 petrol (SWMBO)
aerodynamica
- x 215
Hi Kenny, I have the adjustable rod pair on order currently and spent earlier this evening checking the mounting bolts will remove. They look badly corroded and I feared the worst but some cleaning with wire spinners, repeated soakings with WD, and very slow untightening has seen them each loosen. I also verified they are M12 x 1,25 screws. Screw 16 in the drawing is 75mm long and screw 17 is a bolt and nut of M12 x 1,25 pitch, about 85mm long. I was looking to replace some of these with standard hex ends and not the torx type, not least because these ones are not straightforward to find. I found some in France so far.KennyW wrote: 20 Jan 2026, 10:05 Graeme,
Kenny
Item no 8
I did also find that the trailing control arm (item no. 3) on the off side rear has a very bad bush at the hub - actually the worst of the lot - and so I now have to change this as well.. Also now on order. I think the screw at the hub lower , no. 15, will come out ok and it has a standard hex at the bottom too. I am a little in the dark still about the one at the arm's other end, screw 14. I see that it too has a nut but where is this on the car? it does up through the floor. I ran out of time but I wonder if it is under the boot floor?
Anyway, the final pair of control arms towards the rear (item no. 2) seemed not to have any wear I could see but the rubber of the bushings does look perished and so will be changed too at a future date. There are a lot of bits to these rear assemblies.
Graeme M
aerodynamica
- x 215
Screw 14. Circled here, but where is this nut located?
Graeme M
aerodynamica
- x 215
Looking at it again, I have never removed the wheel arch liner. I have a hope that it might be accessible behind there...
Graeme M
aerodynamica
- x 215
But it isn't!! No access from sides or anything. No sign of anything under the back of the rear seat lower that I can see.
Graeme M
aerodynamica
- x 215
Keep wondering if its really a weldnut this screws in to and that diagram is misleading.
Graeme M
aerodynamica
- x 215
Ok, it's a captive nut. I chanced it and the bolt untightened easily but was concerned it would leave a nut rattling around inside. The nut does move but seems you can use the fairly long bolt that has a hefty lead at the end, to carefully rescrew it in. No idea how the nut is located/ prevented from turning / getting pushed up or otherwise dislodged but it seems to stay. Also no idea how it is even put in there. Maybe they locate it in a recess and assemble the car around it....
Looking up it's a good inch up there. No idea how it's retained
Graeme M
KennyW
- x 165
Graeme,
I replied on your older thread but on reading this thread you are further on,so my reply is irrelevant.
But good luck all the same.
Kenny
Kenny
aerodynamica
- x 215
No worries Kenny, I'm not rushing this job really. Waiting on the parts now
Graeme M
