308 gearbox leak.
Joecolew007
308 gearbox leak.
Unread post by Joecolew007 »
Hi all. I have a leak from the silicone seal between the item no2 in the picture and the main gear housing, my question is can part no2 circled red be safely removed and with everything eles on the car, obviously oil drained out first, it looks like its just a cover bit like a sump on its side. But cant risk a gearbox problem for the sake of repairing a small leak.. its a 1.6hdi engine in a 2012 308. Any help be appreciated. Cheers.
x 8126
Re: 308 gearbox leak.
I don't know if you will get a definite answer from a member on this one but it might be worth addressing your question to a gearbox refurb company like the one in the link below: :)
https://www.reconditioned-gearbox.co.uk ... gearboxes/
x 2938
It is just a cover, ok to remove and reseal, if there's room.
x 1490
Yes, you can remove this - it covers up the 5th gear components, which can also be removed with the box in situ.
x 1463
Unread post by xantia_v6 »
If that cover is rusty, the leak could be due to a pinhole.
Joecolew007
Thats for the information on that... much appreciated. Will look at that in due corse.. cheers.
