Issue with interior fan and central locking from flip key
stoyanganchev
Unread post by stoyanganchev »
Hello! I have an Issue with interior fan and central locking from flip key. When I lock the car with the key it is working, but with the remote control NO. The issue with the fan is that when I press the brake the speed of the fan go up. I checked the minus point near right rear light. When I switch of the brake switch, the issue is gone. I know that is the comfort Modul. Can you help me where to search the problem.
x 8151
Re: Issue with interior fan and central locking from flip key
Does the remote work if you hold the fob next to the steering wheel? :)
stoyanganchev
No it is not working.
PaulC5
x 705
Unread post by PaulC5 »
Have you tried replacing the remote fob battery and initialising it following the procedure in the handbook ?
x 1944
Has the remote ever worked?
x 1056
Unread post by wheeler »
As Paul asked, has the remote ever worked since you have had the car?
Have you tried a new battery in the fob?
Have you checked to see if the fob is transmitting a signal?
Have you tried re programming the fob? Needs to be done diagnostically & will requre the 4 digit security code.
I would hope you have checked all these things before getting involved with removing the CPH?
stoyanganchev
The car was bought as new from my father. It worked but suddenly stop working. The remote is tested and give a signal, but the car didn’t receive it.
stoyanganchev
I tried to relearn the key and the CPH but without success
x 1056
Sounding like its likely a CPH issue then, If you get a second hand unit you would need to copy or swap the EEPROM over from your original.
Note that the CPH has nothing to do with the interior fan though so would need looking at separately.
stoyanganchev
When I lock the car with the key, the warning lights are not turning on like my fathers C5 and the Xsara of a friend. Is it normal?
x 1944
When you say locking with the key do you mean you physically use the blade to turn the key barrel in the door handle or simply press the buttons on the fob?
stoyanganchev
I mean physically use the blade to turn the key barrel in the door handle, then the car lock the doors, without turning the hazard, but when I try to use the buttons on the key is nothing happening.
x 1944
Locking the car with the key blade only locks it, the interior ultrasonic intruder detector is disabled. This might be why you're not seeing warning lights.
You say "The remote is tested and give a signal, but the car didn’t receive it." What was used to test the remote?
stoyanganchev
It was tested on a device in a key repair shop.
