Old school problem: 406 keypad bypass
x 1905
Re: Old school problem: 406 keypad bypass
Gosh that screen shot takes me back 20 odd years to when it was possible to hack into Sky's encryption Videoguard. Anyway, back to the problem in hand.
x 1052
Unread post by wheeler »
Did 0080 work then??
Janne100
x 3
Unread post by Janne100 »
So, I tried all combinations of 1,2,7,0 which seemed to be worn out in keypad. Also tried all combinations of 0 and 8. No success.
As I found info that the code is stored in engine ECU on separate IC B58097 (which acts as a immo-memory), I did this dump. I was finally able to buy new eeprom chips to test the burning and editing the code. I didn't have enough inspiration, so I disconnected the keypad, installed a virgin eeprom, and... car started normally. Case closed. I play with programming with next project :)
x 1905
Excellent work.
x 1052
Nicely done. Where did you get the virgin dump for the ECU?
Janne100
x 3
I didn't make anything. Virgin chip is what comes from factory, I suppose, if read, it's full of FF's.
Note: This applies only to the immo chip, not to big IC handling the tuning maps.
x 1052
Ah so it was just a blank chip then? In theory you could just erase the original chip?
Janne100
x 3
That's true. I didn't want to mess with it to not lose any vital info, but instead bought a blank chip.
And this blank chip method works also when you don't have the burner tool.
Trickiedickie
x 14
Unread post by Trickiedickie »
Unless I am mistaken it is just a case of removing the original chip. No replacement required and the car should start.
Kees
x 144
Unread post by Kees »
I don't think so, because a "empty" ic is filled with "00" or "ff", and with out the ic, it's possible that the data is opposite of the then it should be.
