hesitation when engine cold.
This is the Forum for all your Renault Technical Questions, Problems or Advice.
ray_r400
Unread post by ray_r400 »
hi all
I have a hesatation when my engine is cold.
the short term fuel trim is -100. all the time.
I have changed the plugs leads and coil pack and pre 02 sensor.
the b1-s2 voltage is up and down 0.100v to 0.400v.
so could this be post cat 02 sensor or injectors that is coursing the issue.
I have no fault codes.
2011 1.2 16v clio. 99000 miles
thanks Ray
x 8151
Re: hesitation when engine cold.
I know nothing about Renault engines, however my initial reaction to your post is to wonder if the ecu is getting correct engine temperature info from the sensor? :)
x 1944
You say you have no fault codes. What are you using to check for these?
ray_r400
thank you for your reply
obd 11 scanner.
vd700. also running live data through it.
ray_r400
the temp goes up on the car the same as my scanner reading.
so it seems OK.
x 1944
The VD700 is only about £50 so may not be up to the job. You need to get the car read by a more high end scanner to be sure of codes.
ray_r400
my friend has a snap on zues+ scanner and the
only fault found was oil level sensor.
nothing else.
thanks
x 1944
Yes, that should be good enough!
Have you checked the spark plugs? Some engines are extremely fussy and require not just the right heat range but from a specific manufacturer. Equivalents just don't work properly. I don't know this engine to be more specific.
ray_r400
thank you
yes plugs have been changed 12 months ago.
it was ok then ordered from euro car parts using the reg.
all plugs are in the same condition:, not wet or burnt.
ray_r400
hi does any one know if pre and post 02 sensors are the same.
when I goolgle it it just gives me one sensor.
I might try and change the post as well.
I think my battle is my "short term fuel trim" b1-s2 is -100. so its over fueling .
thanks Ray
should be 0.
ray_r400
I disconnected my post 02 sensor plug
and my reading is still -100 stft. and I still have a voltage.
so does this point to sensor being bad.
thanks Ray
ray_r400
I ran live data with just ignition on and my stft b1-s1is still showing -100 even if car not running.
ray_r400
just realised that the -100 stft is a default.
so this is what I have tried today.
I removed the knock sensor plug to check for voltage and there is no voltage.
0v even with the car at idle.
should I get a reading.
