Hi all,
Is there a way to find out the current firmware version on a device that is stuck in a boot loop due to a bad Micro SD card?
Thank you
RT6 2.75.c.5 Firmware / Software Download
OnlinePaul-R
- x 1903
Re: RT6 2.75.c.5 Firmware / Software Download
Not that I know of. Maybe in a suitably equipped workshop but realistically, no.
Lisali13
- New User
Is anyone able to point me in the direction of the 2.77 please?
OnlinePaul-R
- x 1903
I can send you a link to download an ISO image for 2.77. But first I would like to know why you need it.
Seka
Hello Paul,
First of all, I apologize for my English.
I have a problem with my car's media system. The buttons, parking sensors, radio, and black multimedia screen do not work in the system. Every 15 seconds, you can hear the sound of the CD drive restarting. The fuses are intact, the power supply is coming to the multimedia. I extracted the factory card and saved the configuration file. I do not know which firmware version is installed.
Studying the information about this malfunction, I decided to replace the sd card. I want to try to solve the problem by reinstalling the firmware whith version 2.77. I do not dare to use version 2.86 due to possible problems with resetting to factory settings. Please share the link to download an ISO image for 2.77.
OnlinePaul-R
- x 1903
Check your PM now. I'm not sure it'll fix your problem though.
prco
Hi Paul! I'm having trouble with RT6 in my C4 lounge, black screen and rear camera turning on with no gear. I think that updating it's firmware will fix the problem. Can you give a link to download it? Thanks
OnlinePaul-R
- x 1903
What version are you looking for?
prco
Actualy, I don't know. I think the latest is the best, am I wrong?
OnlinePaul-R
- x 1903
See what you have at the moment.
To identify the audio-navigation system software version of the RT6 observe the following procedure:
Press and hold the "SETUP" button.
Select: Audio/telephone diagnostics ; Confirm.
Select: Description of the installation ; Confirm.
View the software version displayed.
prco
"Soft da unidade - BR:6.2.11:project"
Looks like my version is 2.11, right? I've already tried to update it but RT6 just boot into the pen drive with the newer version and don't install it. Can you teach me the correct way to update the system?
Reason: Image attached
OnlinePaul-R
- x 1903
It actually says 6.2.11 which looks like a version number for SMEG+ IV2 systems. Can you post a photograph of the system in your car? Is it touchscreen?
prco
Paul, finaly I got it updated to 2.86 version, thanks!
OnlinePaul-R
- x 1903
What do you think was the holdup and cure? Or was it just perseverence doing the same thing again and again!
prco
I think just perseverance kkkk the last time I insert the pen drive after the car is turned on, don't think this made any difference but started the install.
