The right hand central air vent is delivering ambient temperature air with the a/c on in my 2016 DS4 Crossback (left hand central vent delivering cold air). This car has the two zone system. My Diagbox comes up with the code B131C1 which talks about “blower control problem” somesuch (forgotten the exact words). The external temperature was 23deg. C and the a/c was set on 18deg.C. Seems to me that the system might need more refrigerant although the error message seems to indicate otherwise. Before I go to a specialist, any ideas?
Although the car is nine years old and has travelled 122,000 km, the a/c has not had a lot of use given that we live in a temperate climate.
Don
Airconditioner misbehaving
PaulC5
- x 696
Re: Airconditioner misbehaving
When our C5 was getting ready for regassing one side would not cool as much. If yours has not been done in 9 years it may need doing.
- x 8132
You should give your aircon a 10-15 minute run every week regardless of your needs. The best way to keep the whole system functioning correctly is to use it and thereby stop parts getting stuck through never being moved. It may be you have a flap actuator problem for the non working side.Ceenine wrote: 10 Dec 2025, 11:04 The right hand central air vent is delivering ambient temperature air with the a/c on in my 2016 DS4 Crossback (left hand central vent delivering cold air). This car has the two zone system. My Diagbox comes up with the code B131C1 which talks about “blower control problem” somesuch (forgotten the exact words). The external temperature was 23deg. C and the a/c was set on 18deg.C. Seems to me that the system might need more refrigerant although the error message seems to indicate otherwise. Before I go to a specialist, any ideas?
Don
Ceenine
- x 17
Thank you for your highlyconsidered reply. Yes, I am cognisant of the need to use the a/c on a regular basis to maintain its functionality, just like human parts.
Any clue as to where I can locate the actuator for this function. I have the glovebox :disassembled ready for action awaiting for direction from you or even others.
Don
Don
PaulC5
- x 696
This ebay listing of a heater might help, the motors will be the black things on the side https://www.ebay.co.uk/itm/177372183135 ... gLiXPD_BwE
Ceenine
- x 17
Thanks for more replies. The whole climate control is certainly a complex bit of kit. Interesting that it had a date label only one month prior to build date and made in the Czech Republic. That is a good example of “just in time” assembly.
I shall try a bit more fiddling before I call in the regas brigade.
Don
Don
