Hi all,
I need help identifying a car. I bought a used Citroen Jumpy, 2015, and the previous owner, for some reason, removed the plate on the driver's door with the OPR code. Can anyone help me with the full complectation using the VIN? My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
best regards
max
How to identify what model engine is in your Citroen
MaxS
- x 1056
Re: How to identify what model engine is in your Citroen
Vehicle characteristics
DISPATCH III LONG GLAZED VAN H1 TYPE 10 2.0 HDi 163 Pef (DW10CTED4) 6-SPEED AUTOMATIC GEARBOX
Vehicle family DISPATCH III
AS/RP N° 13979 U9 1 0185
Warranty Start Date 19/08/2015
Engine serial number 10 WAPE 0500186
OPB G01U
BER e2*2001/116*0350*24
P4A 9803635199
General information
PRODUCT TYPE COMMERCIAL VEHICLE
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY DISPATCH III
SILHOUETTE LONG GLAZED VAN H1 TYPE 10
TRIM LEVEL UPPER LOW
ENGINE DW10CTED4 FAP TURBO DIESEL
TRANSMISSION 6-SPEED AUTOMATIC GEARBOX
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EZR - PAINT ALUMINIUM GREY
INTERIOR TRIM TYPE VEL JOCASTE F916+MISTECO2 F924 "KO"
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) Auto gearbox AM6
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) EW/DW
OTHER BADGE WITHOUT FULLER BADGE
OTHER BADGE, " MISC. " EXCLUSIVE
SPEEDOMETER DRIVE WITHOUT SPEEDOMETER RATIO
Fuel supply-Engine
FAN 2 300W + 460W 3-SPEED FANS
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING DELPHI
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE)
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTOR WITH DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 5 L6 UPPER ENGINE EMISSION CONTROL
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
CATALYTIC CONVERTER 2-COMPONENT PLATINUM FILTER CATALYSER
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
VALVE PER CYLINDER 4
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
DEVICE (ANTIPOLLUTION) EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTION TECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
Gearbox Transmission
GEARBOX TYPE AM6 AUTO GBOX NORM EURO5
FINAL DRIVE RATIO AXLE TORQUE 15 X 53
WHEEL STYLE 16 INCH VIVACE WHEEL
CLUTCH WITHOUT CLUTCH
DIFFERENTIAL (GEARBOX) W/O GEARBOX DIFF
RIM/TYRE SIZE 16 INCH TYRE FITMENT
TYRE (SIZE, TYPE) 215/60 R16 99T REINFORCED TYRE
DRIVING WHEELS 2 DRIVEN WHEELS
WHEELS FITTED 7" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR LOSS OF INFLATION PRESSURE INDICATOR EU STANDARD 64.02
Suspension-Steering-Brakes
STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC STEERING
ABS WITH ABS BRAKES
STEERING COLUMN MANUALLY ADJUSTED STEERING COLUMN
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
POWER STEERING FLUID COOLING SYSTEM WITHOUT POWER STEERING OIL COOLING
SUSPENSION FR/RR HEAVY DUTY SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
Body fittings
EXTERIOR STYLING PACK WITHOUT BODY COLOUR EXTERIOR
TOWBAR WITHOUT TOWBAR
AERIAL LONG ROOF AERIAL
CABIN WITHOUT CAB
CHASSIS LONG CHASSIS
PAYLOAD LOAD CAPACITY 815 KG
SIDE MOULDINGS (TYPE) BODY COLOUR LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE) VIVACE WHEEL EMBELLISHER
UNDERBODY SHIELD WITHOUT PROTECTION UNDER BODY
INDICATORS WITHOUT SIGNALING LIGHTS
THIRD BRAKE LAMP WITH EYE LEVEL REAR LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE) ENGINE UNDERSHELDING
DRAUGHT EXCLUSION WITHOUT AERODYNAMIC SEALING
EXT. LOAD RETENTION RING (ATTACHMENT) WITHOUT DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRIC FOLDING EXTERIOR MIRROR
ENGINE BAY SOUNDPROOFING BULKHEAD+COVER/BONNET+HEAT SHIELD SOUNDPROOFING
OPENING OF MOVING PANEL WITHOUT OPEN THE DOOR
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER WITH REAR WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
REAR SCREEN WIPER (OPERATION) AUTO INTERMITTENT RR WIPER IN REVERSE GEAR
SIDE LOAD DOOR RH SLIDING SIDE WINDOW DOOR
BUMPER BODY COLOUR FRONT/REAR BUMPER
MUDFLAP WITHOUT MUDGUARD
ROOF STANDARD ROOF PNL
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) DRIVER’S DOOR MIRROR ELECTRIC CONTROL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES LION GREY EXT HANDLES + BODY COLOUR EXT MIRROR
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) DOUBLE GLASS EXT MIRROR
SUN ROOF WITHOUT SUN ROOF
BODY CONVERSION WITHOUT
BODY PROTECTION WITHOUT
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED FR + OVERTINTED SIDE RR + TINTED TAILGATE
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
WINDOW (TYPE) TOUGHENED WINDSCREEN + REAR SIDE
SIDE WINDOW (COMM. VEH. ONLY) SLIDING SIDE WINDOW
ROW 3 SIDE WINDOW FIXED WINDOW GLASSES,3ND ROW
Interior fittings
SEATING ASSOCIATED VARIANT VARIANT ASSOCIATED STANDARD SEAT CUSHION
CHILD OBSERVATION INTERIOR MIRROR INTERIOR CHILD MONITORING MIRROR
AUDIO PACK AUXILIARY SOCKET 1 JACK SOCKET + USB + BLUETOOTH
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER WITH FRONT LIGHTER
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT FRONT HEADREST ADJUSTABLE
REAR SEAT BENCH SEAT PF R2 + SEAT DEP INCL 3P + 1 ACD
SUPPLEMENTARY SEAT BENCH SEAT PF R3 + TILTING REMOVABLE SEAT 3P
REAR SEAT ARMREST WITH REAR SEAT ARMREST
CABIN SEAT 2 PLACES PASSENGER BENCH
LUGGAGE COVER PARCEL SHELF + SCREEN
REAR SEATBELT RETRACTOR+RETRACTOT LAP
FRONT SEATBELT DRIVER ALARM INERTIA + PASS 2 ALARM SS INERTIA
CLIMATE (AMBIENT TEMP) VERY COLD COUNTRIES
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GRAB HANDLES HANDLES FR PASS + RR + ADDITIONAL + HOOKS
SUPPLEMENTARY SEAT ADJUSTMENT ADD SEAT TILTING BACK
DRIVING POSITION LEFT-HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
ADDITIONAL HEATING AUTOMATIC ADDITIONAL HEATING
BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENT TIN DECORATION FASCIA PANEL
INT. TRIM AND EQUIPMENT VARIATION CLOTH INT SIDE PROTECTION TRIM
MISC. INT. LAMPS REAR MAP READING LIGHT + SPOTLIGHT
WORK TABLE WITHOUT WORK TABLE
LOAD SPACE TRIM W/O MAT
FRONT SEAT RUNNER WITH RUNNER
FRONT HEAD RESTRAINT (STYLE) FULL FRONT HEAD RESTRAINT
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 190 KM/H OR 120 MPH BLACK BACKGROUND
LOUDSPEAKER 2 FT SPEAKERS + 2 RR SPEAKERS
TIMER WITHOUT TACHOGRAPH
RADIO CONTROLS REMOTE RADIO CONTROL
ADDITIONAL BLOWER WITHOUT ADDITIONAL PULSE
SIDE DOOR CONTROL MECHANISM WITHOUT SIDE DOOR CONTROL
SUPPLEMENTARY SEAT HEAD RESTRAINT ADJUST HEADREST EXTRA SITTING
PASSENGER COMPARTMENT SOUNDPROOFING 7 KG BULKHEAD SOUNDPROOFING
DRIVER SEAT CONTROL MANUAL DRIVER’S SEAT CONTROL
FRONT PASSENGER SEAT CONTROL W/O PASS FRONT SEAT CNTRL
DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENT WITHOUT FRONT PASSENGER’S SEAT ADJUSTMENT
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT WITHOUT REAR GLASS LIFT
CABIN CARPET FR+RR PASSENGER COMPARTMENT MATS
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
MISC. INT. ACCESSORY WITH CUP HOLDER
SUPPLEMENTARY SEAT SEATBELT SUPPLY SEAT - INERTIA-REEL BELT + STATIC LAP
COURTESY MIRROR PASSENGER SIDE WITHOUT LIGHTING
FOOTREST DRIVER’S FOOTREST
OIL GAUGE INSTRUMENT PANEL LEVEL + TEMPERATURE
HEATING ELEMENT DRIVER’S HEATED SEAT + BENCH SEAT R1
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
PASSENGER AIRBAG PASSENGER AIRBAG
ADDITIONAL AIR CONDITIONING WITH ADDITIONAL AIR CONDITIONING
HEATING DUCT HEATING DUCT FRONT + REAR
ON-BOARD COMPUTER COMPUTER
EQUIPMENT PACK W/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
REAR MOVING PANEL TAILGATE
COURTESY LAMP FR COURTESY LAMP FR DOOR CTRL+RR REMOTE CTRL
FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
STORAGE (DRIVING POSITION) LOWER STORAGE COMPARTMENT WITH LOCK + COOLED
RADIO RECEIVER RD45 MP3 RADIO CD/REMOTE DISPLAY
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL REGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROL PASSIVE PARALLEL ADJUSTMENT
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
CARPET NEEDLED CARPET DILOUR F550
LIGHTING TIMER WITHOUT TIMER
INTERIOR PROTECTION WITHOUT INNER PROTECTION
OBSTACLE DETECTION SYSTEM OBSTACLE DETECTOR
LATERAL BLINDS WITHOUT SIDE BLINDS
FLOOR MAT W/O CARPETMAT
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL LEATHER STEERINGWHEEL
Electrical
ALTERNATOR ALTERNATOR CLASS 18 180 AMP
BATTERY BATTERY L3 450
STARTER MOTOR STARTER MOTOR CLASS 6+
SPECIAL LIGHTING AUTOMATIC HEADLAMP ILLUMINATION
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENT WITHOUT BATTERY CHARGE MEASUREMENT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION COMBI WITH RCE
MODIF. DURING MODEL YEAR 1ST MINOR MODIFICATION
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL RUSSIA LABEL
RADIO HEADPHONE SOCKET DOUBLE ACCESSORY SOCKET
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
PLATE WITHOUT PLATFORM FLOOR
SET OF KEYS 1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
OPB G01U
P4A 9803635199
General information
ENGINE (TYPE) EW/DW
Fuel supply-Engine
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
ABS WITH ABS BRAKES
Body fittings
CABIN WITHOUT CAB
Interior fittings
Electrical
Miscellaneous
LABEL RUSSIA LABEL
Andyquoys
Hi, please help identify my Citroen spacetourer.
Vin VF7**************[VIN obfuscated, can be read by forum staff].
Andy
Andy
enzso
- New User
Just bought a Berlingo B9 and want to check the timing belt change interval please. VIN VF7**************[VIN obfuscated, can be read by forum staff]
PraguePicasso
Hello everyone. Very proud new owner of a 2013 b78 C4 Picasso here. Can someone help me with engine code and build sheet? Thank you so much.
VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
- x 1945
Your engine code is 9HC, which equates to the DV6C engine. 85kW.
PraguePicasso
Thank you Paul. If someone can take the time to help with full build sheet as well, it would be greatly appreciated!
Refrigato
Hi guys, my dad bought a Citroen c3 earlier this year and he now realised that it was originally registered as commercial vehicle even though it now is in a passenger format. He’s wondering what equipment was the original and what has been modified - out of curiosity mostly as he’s satisfied with the car in its state. Can anybody help provide this detail using the VIN VF7**************[VIN obfuscated, can be read by forum staff].
kakavia
I am very impressed by the details you give.
Is it possible to have these details for my car with VIN:VF7**************[VIN obfuscated, can be read by forum staff] ?
I would like and the service schedule please.
Much obliged.
Much obliged.
Citroen C4 Cactus '19
1.5 BlueHDi 100
1.5 BlueHDi 100
PaulC5
- x 705
On the 1.5 hdi engines there is a recall MXL which you should have done at the dealer at no cost to you. They listen to the engine and if it sounds ok they change the oil and filter to the latest oil spec. If not ok then they might fit another cam shaft chain and cam shafts.
kakavia
I have an appointment on March for this issue. There are a lot of cars that need to be checked and the appointment is in 3 months.PaulC5 wrote: 22 Dec 2025, 11:57 On the 1.5 hdi engines there is a recall MXL which you should have done at the dealer at no cost to you. They listen to the engine and if it sounds ok they change the oil and filter to the latest oil spec. If not ok then they might fit another cam shaft chain and cam shafts.
1.5 BlueHDi 100
1.5 BlueHDi 100
