It just occurred to me that this is what's probably preventing the car from starting.ozfrog wrote: 26 Nov 2025, 13:11 It tells me that there is a fault with the radio - but we've never observed one. I really don't know what to say about that!
Any way to get around ‘Economy Mode’?
ozfrog
- (Donor 2026)
- x 73
Re: Any way to get around ‘Economy Mode’?
Cheers,
Andrew
Andrew
- x 1480
After you have done the global scan you should be able to click on each ECU that is showing faults and it should expand and give you a list. Clicking on each fault should then give more details. If you double click on the ECU then it will take you into that ECU where you can then click on read faults for full details.
If you go into the BSI, then activation tests, you should be able to find the windows somewhere.
ozfrog
- (Donor 2026)
- x 73
I’ll try and get some screenshots later this evening.wurlycorner wrote: 26 Nov 2025, 14:29 Taking photo's of the screen and posting them on the forum, is the simplest way with diagbox, I find.
[We’re down to one working car at the moment and the boss works about 50 kilometres away from home - and she won’t drive a manual car, anyway. My poor 406 is clocking up the kilometres at a great pace, with reduced compression in two cylinders because of leaking copper gaskets between the injectors and the cylinder head. I’d drive back home and get those screenshots done, and the detail of the various faults, now if the car was in better condition. I don’t think it’s doing much good driving around with those two leaking cylinders.]
Cheers,
Andrew
Andrew
- x 1480
What engine is in the 3008? Does it still crank?
ozfrog
- (Donor 2026)
- x 73
It doesn't crank.
It's a 2.0 HDi Turbo Diesel. Would it be an RHH engine? I can provide the VIN if that helps. VF3**************[VIN obfuscated, can be read by forum staff]
Steve Walsh
- x 515
Put ignition in on, Jump the starter to crank while giving it a snort of Easy start, if it fires you are half way there. It might also unlock from economy mode
ozfrog
- (Donor 2026)
- x 73
I've just spent about 2 hours getting screenshots on this ancient laptop. I already hate Windows. Now when I go to open the document, all I see is a bunch of paragraph marks. I'm not dealing with this again tonight/this morning.
Cheers,
Andrew
Andrew
wurlycorner
- x 271
Oh by photo's I meant literally taking a photo of the screen with smartphone, rather than screenshots.
Iain
CX DTR T2 Safari (silver)
Iain
- x 1480
So if it won't crank, then either the starter has failed, the wire to it has given up, the BSM has thrown in the towel, the fuse is blown, or there is some reason the ECU is not switching the starter on - is it an auto? Always assuming that it isn't just a flat battery! So most you can diagnose without the computer.
Starter on a 2.0 is easily accessible down the front of the engine.
1st, Check it's in neutral, then short the two big terminals on the starter with a screwdriver to see if it cranks. This will rule out the motor part, or indicate a wiring or motor fault. If the ignition is in the run position, it should start if it will crank.
Assuming it will crank, then check whether you are getting 12V on the exciter wire when the key is turned to crank. If not, try running a bypass direct off the battery and see if it will crank.
If no voltage, find the starter fuse and check it (actually I would do that first...). Check that you get 12V on both sides when the key is in crank position. If you do, but no voltage at the motor, then broken wire or BSM fault. If you don't then off to the diag tool to see if it is giving the start signal.
- x 1921
Yes it's an RHH. I've corrected your VIN so that the forum software works properly obscuring it.ozfrog wrote: 27 Nov 2025, 11:34It's a 2.0 HDi Turbo Diesel. Would it be an RHH engine? I can provide the VIN if that helps. VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
ozfrog
- (Donor 2026)
- x 73
What did I do incorrectly with the VIN?Paul-R wrote: 27 Nov 2025, 18:37 Yes it's an RHH. I've corrected your VIN so that the forum software works properly obscuring it.
Unfortunately, yes.RichardW wrote: 27 Nov 2025, 18:30 … or there is some reason the ECU is not switching the starter on - is it an auto?
Although I’m not sure if there’s any difference between the two positions in the transmission itself, before I called roadside assistance, I did attempt starting the car in both neutral and park positions on the selector lever, a few times. Roadside service did the same thing when they arrived, and I have tried it since the car has been at home.
I’m still working my way through the items in the other post(s).
Cheers,
Andrew
Andrew
- x 1921
You typed it in as starting with the letter 'U' and it should have been a 'V'.
ozfrog
- (Donor 2026)
- x 73
I must have been half asleep! I know that it should begin with a V
Sorry about that.
Sorry about that.
Cheers,
Andrew
Andrew
OnlineSloppysod
- x 386
It's been 18 months or so since I looked at my Diagbox, but if my memory serves me right, once you have completed the Global test, look for a printer icon (top right?) That will print all the faults as a xml file, then search web to xml file viewer, then print.ozfrog wrote: 26 Nov 2025, 13:11 ......Now, I performed a global test and unsurprisingly, there are multiple errors, but I can't get the software to give me details about the faults, plus I've forgotten how to get the messages to print to a file. I did what I thought was the correct method - and it promptly crashed Diagbox with a Run Time error. So I had to redo all of the Gloabal Tests and I still can't remember how to get the detailed information about each item that has an error next to it, and nor can I remember how to print these report to a files.
Stu
ozfrog
- (Donor 2026)
- x 73
I think your memory has served you well!Sloppysod wrote: 28 Nov 2025, 10:17 It's been 18 months or so since I looked at my Diagbox, but if my memory serves me right, once you have completed the Global test, look for a printer icon (top right?) That will print all the faults as a xml file, then search web to xml file viewer, then print.
I think I did pretty much what you wrote. My only problem was the Run Time Error and I couldn’t find an explanation.
Cheers,
Andrew
Andrew
